First post, by kirikl
Hello everybody. I can't find DOS drivers for Clik.
I made PCMCIA drivers work finally in DOS! Hallelujah!
So clik actually squeak (beep) when DOS PCMCIA drivers loaded, as it should...but now I need some kinda driver.
I tried trial version of ATAENAB - it doesn't work with pocket zip/clik.
Now iomega guest 6.0 just hangs forever...
I actually found folder with Win9x tools installed and there is guest.exe in it too! But it's also version 6.0 and it does the same thing... hangs on finding the drive....
Is it even possible to make it running DOS?
Or it requires at least Win 3.x?
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
Reply 2 of 2, by kirikl
lolo799 wrote on 2024-02-28, 10:22:
The Clik! drive (pcmcia or parallel port adapter) requires at least Win95.
It also works in Windows CE on some devices...
That's what I thought... I ordered USB pcmcia ATA reader. Maybe I can read clik on a bigger computer
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
