First post, by crusher
Does anybody know how to hide system/hidden files in Volkov Commander such as msdos.sys, io.sys etc?
I could not find an option in settings.
But I can't imagine this is not possible.
to hide files with "hidden" attribute set: alt, select left/right, filter, uncheck "hidden files"
do note that "hidden" and "system" are different attributes - you can have non-hidden system and hidden non-system files. use them appropriately.
Thank you, that worked!
BUT:
VC doesn't seem to remember that setting. Next start of VC the hidden files are shown again.
Is there a way to permanently set this option?
Shift-F9 ?
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Yeah, that's it! 😀
Thanks both of you for your help.
Much better now 😉
