Reply 100 of 109, by bofr
Hello.
Registered here with the main purpose of simply saying "thanks"!
This mixer is just what the doctor ordered and i really wish something like this existed in the old days!
Using an audigy1, external mt32-pi for midi and internal ymf715 for mpu out and opl3.
SB16-emulation from the audigy, it is "good enough" for my purposes.
One small question/suggestion though. Would it be possible to add an option for manually setting a register?
(I read that you lost contact with the programmer, I can figure it out myself but it would help if you could find the part in the source code that accesses the card and sends commands)
There are gobs of weird settings internal to the card to mess with, presumably only crazy people would bother but i do have a use case,
in that I would try to get i2s working with external non-creative things.
Supposedly the audigy has an improvement compared to the older live series, it SHOULD be possible to change from master to slave mode.
But I need to send direct commands to the card to test it.
/bofr
