OPL2LPT
Reply 540 of 567, by X3NoMoRPH
Hi !!! recently a friend made me an OPL2LPT, and I am testing it in a minipc with FreeDOS, v1.3, that uses the JEMM memory manager, then:
adlipt JLOAD JADLIPT.DLL
¿ this command does not work, it is as if it does not exist ? , what's wrong ?
thx 😀
EDIT: I have used EMM386.exe memory manager, I have already solved it that way.
Reply 541 of 567, by digger
Glad you found an alternative solution, X3NoMoRPH!
But I think you should have left out `adlipt` in the command you tried. So my guess is that the command `JLOAD JADLIPT.DLL` would probably have worked, provided that JLOAD (part of Jemm) was in the path, and you were currently in the adlipt directory containing that DLL file.
Reply 542 of 567, by X3NoMoRPH
digger wrote on 2021-10-09, 09:02:
Ahhhhh ... I didn't know that "Jload" is part of JEMM, okay I was going crazy about it, thanks.
Reply 543 of 567, by Cloudschatze
Here are a couple of versions of Koei's FM sound/music driver that I've patched for use with an OPL3LPT at 0x378.
fmdrv310.zip - OPL-II Sound Driver Version 3.10
  • Known compatible with the following:
    • L'Empereur
    • Gemfire
    • Liberty or Death
    • Romance of the Three Kingdoms II
    • Uncharted Waters
fmdrv311.zip - OPL-II Sound Driver Version 3.11
    • Nobunaga's Ambition - Tales of the Conquerors (信長の野望・覇王伝)
    • Romance of the Three Kingdoms III - Dragon of Destiny
    • Uncharted Waters - New Horizons
fmdrv100.zip - Sound Blaster BGM Driver Version 1.00
    • Genpei War (源平合戦)
    • Nobunaga's Ambition - Chronicles of the Ascension (信長の野望・天翔記) (Rename the driver to SBOPL2.COM)
I suspect that these modified drivers will not work correctly with an OPL2LPT due to the greater write-delay requirements of the OPL2. I'd certainly welcome confirmation from anyone with one of those devices.
Reason: Restoring revision 67833
Reply 544 of 567, by Cloudschatze
Here is a set of drivers for Zeliard that have been patched for use with either the OPL2LPT or OPL3LPT at 0x378.
Reason: Restoring revision 67834
Reply 545 of 567, by Cloudschatze
Here are executables for Eye of the Beholder I and II that have been patched for use with an OPL3LPT at 0x378.
Reason: Restoring revision 67835
Reply 546 of 567, by ruthan
Is not possible to upload all these fixes to some united OPLxLPT online repository?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 547 of 567, by digger
I was wondering: instead of hard-coding it, how hard would it be to make the I/O base port dynamic in some (or all?) of these patches?
Perhaps by obtaining it from the BIOS Data Area (which would be 0040h:0008h for LPT1)?
That would allow it to work, regardless of whether LPT1 is located at 0x3BC or 0x378. Also, it would allow for the creation of a utility that could look up the non-standard base port of a PCI Express LPT card and update the BIOS Data Area accordingly. One could then load that utility before starting a patched game.
Crazy idea?
Reply 548 of 567, by RetroBard
I recently got the OPL3LPT and was able to successfully patch some Sierra SCI games. Codename: Iceman’s adl.drv wouldn’t patch for some reason, stating that the file could not be found. I circumvented that by copying a patched adl.drv from another Sierra game. The sound is a bit quiet but it works.
Is there any chance of getting native support for Indianapolis 500? Would love to hear Rob Hubbard’s melodies through the OPL3LPT.
Reply 549 of 567, by matze79
digger wrote on 2022-01-18, 23:23:
I was wondering: instead of hard-coding it, how hard would it be to make the I/O base port dynamic in some (or all?) of these pa […]
Crazy idea?
The TSR is opensource, you can fetch it and add features.
Reply 550 of 567, by dreamblaster
Prototyping a new version of OPL2LPT : "OPL2LPT V2"
Thanks for your support !
Reply 551 of 567, by matze79
Smaller footprint, so it will fit more PCs!
*Like* 😀
Reply 552 of 567, by s|ugfish
I'm using the Opl2LPT2 v2 on a lenovo m32 thin client .running free dos . I was wondering if anyone had any sugrestions to reduce the level of buzzing I'm currently encountering with it. I've tested it with an exsternal power source, and using usb power from the m32 . In both cases the volume is very low, and their is a high level of 'noise' . Initialy i thought it was a grounding loop or some crappy speakers but i've tested multiple speakers and tried swaping to an exsternal power source. Any sugestions would be much appreciated.
Reply 553 of 567, by dreamblaster
here are some suggestions :
- press the reset button after bootup, to reinit the chip, does the noise go away ? This is needed for some pc's, depending on the bootup order and states of parallel port during this. Check parallel port settings in the bios.
- turn the pot all the way and then back to the middle. while testing opl2, the volume can go pretty loud, so if the volume of music stays low there sure is something broken.
- connect a headphone directly and listen through this ? does it sound good ?
- use an usb powerbank as power source, see if this also has the same noise.
if you cannot get it sounding good,
send me a pm or contact me through https://www.serdashop.com/Contact
I will support you in this, and send a replacement if your opl2lpt is broken
Reply 554 of 567, by dreamblaster
MemberA2600 let me know, he is working on a Video Game Music Player for the OPL2LPT sound card on modern Windows.
see https://github.com/MemberA2600/OPL2LPTVGMPlayer
Reply 555 of 567, by Jo22
Ah, that's cool! Reminds me of my parallel port experiments with Win 3.x/9x and Visual Basic back then!
On Windows NT, PortTalk or Port.dll can help accessing the LPT ports.
The programs using it can still be 9x compatible, afaik.
Reply 556 of 567, by Jo22
dreamblaster wrote on 2023-01-29, 11:10:
It looks very good, there's just one minor complain, maybe: The resolution is a bit over 1024x768 (1.025×858)..
It the window was a little bit smaller, it would be compatible with LCDs from the Windows 98/XP era.
Or laptops. Some slightly older models from the 2000s do have 1024x768 screens and an LPT port.
Many of them could run Windows Vista/7, if needed, which technically is a modern Windows.
Edit: Picture added.
Edit: Ah! It's an Win64 application ?! If so, then never mind, it wouldn't run there anyway.
(I'm not entirely sure, since it doesn't run on Win XP SP3 but has an inpoutx64.dll file.)
Reply 557 of 567, by MemberAtari
Jo22 wrote on 2023-01-29, 17:56:
No, it's a 32bit one. 😀 inpoutx64.dll was not working, so I had to do do it as a 32bit application. 😀
My original plan was to size it for 1024 * 768, but I run out of space on the window. 😁
Reply 558 of 567, by Jo22
MemberAtari wrote on 2023-01-29, 18:32:
Hi there! Thank you for writing back! 🙂
Your program is fine, my "complaint" was just meant as a form of feedback, I hope you don't mind. 😄
Reply 559 of 567, by MemberAtari
Jo22 wrote on 2023-01-30, 05:54:
No, I'm pretty happy if people find it useful. 😀 I made it as a tool since I'm working on a really huge Atari 2600 project for two years and one part of it is adding basically an Adlib add-on to the second joystick port. And for that, if I want to test how the music should sound, the perfect way is to use my work PC instead of turning my music-player DOS PC on. 😁 (most Atari 2600 projects are about the graphics update, I'm focusing more on the music part, even the C64 had an OPL add-on).
