First post, by bionicle_159
I've purchased an old 2006 X-Fi with the classic Soundblaster front panel and of course straight after LGR posted a video on it - pointing out the proprietary mini-din connector for MIDI devices!
I would really appreciate someone to do a simple write-up of the pin-out as this would save myself a big headache with dealing with eBay sellers, as the prices for the adaptor cables are annoyingly high on eBay UK for what is essentially a simple wire conversion.
Work Rig - Ryzen 2700X, 16GB 3200Mhz, MSI B450 LN91340, HD 7970 Ghz (I know...), SB 1500
XP Rig - C2Q Q6600, 4GB 800Mhz, GA-P31-DS3L , GTX 750Ti, SB 0820
98SE Rig - AthlonXP 1700, 512MB 166Mhz, NForce A7N8X-X, V3 2000 PCI, Aureal Vortex 2 SQ2500
Reply 1 of 18, by Salient
I measured my own cable and came up with this:
Male mini DIN:
Female DIN end:
I only use the MIDI out of my X-Fi so I am not totally sure if the other conversion cable could be different but as I recall it, they are both the same and not specifically labeled for MIIDI IN or MIDI OUT.
Reply 2 of 18, by bionicle_159
so are the blank pins ground?
Reply 3 of 18, by Salient
Blank pins are not connected anywhere.
Reply 4 of 18, by bionicle_159
Thanks for clearing that up for me, I knew I could count on VOGONS for support! I'm sure this will help a lot of people who are bound to run into the same issue. I'll order the connectors in the next few weeks, perhaps in the future I might design a low-profile 3D printed block adapter that simply plugs into the recessed area of the front panel MIDI port.
Reply 5 of 18, by bionicle_159
*This may come across a bit daft but what is the blue section for? I was under the impression that the notch was just for lining up the connector, not having any electrical relevance.
Reply 6 of 18, by Kamerat
Usually that's connected to the cable shielding.
YouTube channel
Reply 7 of 18, by Tiido
Shields and grounds are to be connected only on one end (one connecting to MIDI out) on the MIDI cables to prevent ground loops from happening.
Reply 8 of 18, by OldDog_Rigo
Hi there, just wondering if there was any chance i could get those mini MIDI to Standard MIDI drawings? I also have the front panel inputs but no cables.
Thanks.
Reply 9 of 18, by bionicle_159
OldDog_Rigo wrote on 2020-10-05, 05:40:
Thanks.
Couldn't find a web archive, but here's a link to a manufacturer, not had any luck in getting replies though.
https://m.alibaba.com/product/60697438789/lin … .b1b748dahuD3ZT
Reply 10 of 18, by Srandista
Thanks.
Here you go:
Male mini DIN:
The attachment SB X-Fi MIDI Pinout - miniDIN (Male).jpg is no longer available
Female DIN end:
The attachment SB X-Fi MIDI Pinout - DIN (Female).jpg is no longer available
Reply 11 of 18, by bionicle_159
Srandista wrote on 2021-02-07, 21:19:
Here you go:
Male mini DIN:
Female DIN end:
[/quote]
Thanks for finding an archive of the images, shame I didn't see this earlier.
I found a couple more online related to this, including one from an old topic Creative Labs Sound Blaster Live! 5.1 40-Pin Header (cached version = https://lh3.googleusercontent.com/proxy/9PqgW … XODl6EkFtuX85FA) and http://nerdlypleasures.blogspot.com/2010/
Hopefully these links will help if the Vogons images go missing again
Reply 13 of 18, by bionicle_159
SScorpio wrote on 2021-02-08, 22:40:
Here's another link, not that the view of the mini DIN is from the perspective of the Live Drive, so it's flipped from the other images.
https://pinouts.ru/Audio-Video-Hardware/minid … in_pinout.shtml
Thanks for helping out!
(I wish there was an upvote option, don't want to spam the forum - this old thread has enough replies from me 🤣)
Reply 14 of 18, by fsmith2003
Has anyone successfully made one of these adapters? Hoping to make one myself but I’m not experienced in what materials I need to buy to make it happen?
Reply 15 of 18, by SScorpio
fsmith2003 wrote on 2021-10-11, 13:48:
You need a 5 pin male mini din, and a 5 pin female din ends, along with at least a three-wire cable. You'll need to solder the wires to the connectors.
I recommend Aliexpress or another site for the cheapest price on the connectors if you don't mind waiting, just be sure to order a few in case you mess anything up. You are working with a small contact points in the mini din plug.
Reply 16 of 18, by aureal
Does a PS2 to AT adaptor work? The plugs look the same but I'm not sure if it's wired up inside the same .
Reply 17 of 18, by SScorpio
aureal wrote on 2021-10-28, 14:04:
No, the PS2 side of those are six pins, you need five.
Reply 18 of 18, by aureal
That extra pin shouldnt be a problem because the extra stuff on the male end can be ripped out but I just checked the wiring... it doesnt match up with the midi-mini midi adaptor so it would still require rewiring the cable.
