First post, by Babasha
- Oldbie
Are there any Ensoniq Soundscape compatible game-lists or game collections?
Need help? Begin with photo and model of your hardware 😉
COW CHIP
COW CHIP
The Opus card runs on a different port address than the other Soundscapes if I remember right. Sometimes you need to edit a game cfg to get it set to the right address. It's a little compatibility quirk.
I like that it still has the Motorola CPU. Don't need EMM386 with the card right?
As for games with native Soundscape compatibility, it started to show up in early 1994. Offhand I recall that LucasArts and games that use HMI sound middleware support it. But you can always choose General MIDI for music. I ran it alongside a SBPro for best game compatibility.
swaaye wrote on 2021-12-20, 23:21:The Opus card runs on a different port address than the other Soundscapes if I remember right. Sometimes you need to edit a game cfg to get it set to the right address. It's a little compatibility quirk.
Tnx for info! Find gameslist “by Soundscape soundcard” on mobygames.com
