First post, by Kahenraz
- l33t
I have a couple of these Midiman MPU401 ISA cards and one if them is broken with the fault being that the card is not detected. This error can be demonstrated with the Duke3D setup.
I found that the 74HC74AP chip (top left) would get extremy hot which is not characteristic on any of the working cards. I replaced this chip and it no longer gets hot but the cards remains undetected. I also swapped the two large socketed chips in the center which includes the ROM and confirmed that they are working fine. I also applied de-oxit to the socket pins and tested continuity with their solder points on the board. I found no obvious shorts between any of the resistors or capacitors and there is no visible damage to the board.
I'm not sure what else to do other than start replacing chips one at a time.
Here are some photos of the cards. They are otherwise identical but I have marked the problem card with a small red sticker.
