Reply 40 of 380, by ldeveraux
sorry again, so preorder not yet available for this?
Reply 42 of 380, by Schyz
Will it just initialize on boot or it requires a TSR? How much basic memory does it consume?
If the gameport is set to the PCMIDI expansion card, does it mean it can only be used for MIDI or it can still be used with joysticks under MS-DOS on the standard address?
Reply 44 of 380, by Schyz
keropi wrote on 2022-04-24, 12:11:
There is jumper to select if gameport midi is controlled by pcmidi or cmi8330
So, if the gameport is set to the PCMIDI expansion card, does it mean it can only be used for MIDI or it can still be used with joysticks under MS-DOS on the standard address?
Reply 45 of 380, by keropi
Schyz wrote on 2022-04-25, 16:26:
gameport can still be used for joystick at the same time with a midi device, the jumper just selects what midi signal is used: CMI8330 or PCMIDI
Reply 46 of 380, by Kahenraz
I thought that all of the CMI chips were horrible for DOS games. Or is just all of the PCI ones? This is a very interesting project. Can you explain more about it's origin and your choice of sound chip?
Reply 47 of 380, by darry
Kahenraz wrote on 2022-04-25, 17:50:
I have heard relatively good things about the DOS compatibility of HW revs of the 8738 that have that functionality integrated. Apparently, the newer HW revs do away with it. I do have an older one in my parts stash, but I have never tested its DOS abilities, AFAICR .
Reply 48 of 380, by matze79
i have CMI Card and it sounds very good at LineOut.
One of the most underrated chips for ISA Sound Cards.
Well, of course is mostly on Cheap Mainboards (PC-Chips) or very Cheap Soundcards.
And often they lack a good analog Circuit.
But many Cards have Jumpers to bypass the Amplifier Circuit.
Reply 49 of 380, by appiah4
darry wrote on 2022-04-25, 18:55:
Can you elaborate on these revisions? I have one PCI CMI card in my stash and I always regarded it as useless junk.
Reply 50 of 380, by Kahenraz
Maybe it's the PCI cards that are junk. I didn't even know these came on ISA cards.
Reply 51 of 380, by imi
I've heard mostly good things about them, also the PCI ones, it's just that they often get used on extremely cheap cards with bad PCB designs.
Reply 52 of 380, by Joseph_Joestar
Kahenraz wrote on 2022-04-26, 12:40:
The CMI8330 is a really nice chip for DOS gaming.
Here's my review of a CMI8330 integrated on a PC Chips M571 motherboard. And here's Gerwin's review of a standalone card based on it.
My retro builds
Reply 53 of 380, by darry
appiah4 wrote on 2022-04-26, 06:39:
I don't know much about them first hand, but threads such as this one Cmedia CMI8738 - maybe its Biggest Secret have mentioned the revisions .
Reply 54 of 380, by darry
I want an MK8330 and am looking forward to finally testing out a proper CMI8330 implementation. The potential for S/PDIF output is of particular interest to me.
My homebrew S/PDIF project has been dormant for a while, but I have slowly been collecting extra hardware. I now have enough hardware for 6 S/PDIF inputs and also have one of these https://www.presonus.com/products/firestudio-project for analogue input purposes (I should no longer need an external standalone mixer). The dedicated host meant to run this is now based on an I5 11400 CPU, so I should have CPU cycles to burn.
Anyway, it is going to be fun "measurebating" the CMI8330's performance over S/PDIF . All joking aside, CMEDIA's chips from that era are probably underrated due poor/cheap/compromised implementation and the MK8330 will likely give us a taste of what could have been had somebody actually put in some effort at a proper design at the time .
Thanks and congratulations for all the hard work!
Reply 55 of 380, by janih
darry wrote on 2022-04-29, 06:44:
As the MK8330 doesn't route wavetable audio through S/PDIF would that be an issue to you? Would you somehow mix wavetable/midi audio to your digital input when using MK8330?
Reply 56 of 380, by darry
janih wrote on 2022-04-29, 06:52:
I use an earlier variant of this https://www.serdashop.com/CHiLL3 for my wavetable daughterboard needs (currently an X2, with an X2GS on the way). IMHO, there is no better way to get clean, noise-free sound from a waveblaster daughterboard . TBH, I am admittedly a bit of an extremist on these matters, but again IMHO, the less one needs to use the analogue inputs on any vintage sound chip's integrated mixer, the better will one's experience be .
I use an external console mixer with multiple soundcards and external synth modules and I only unmute what I need at any given moment .
Feel free to think that I am a bit crazy .😉
Reply 57 of 380, by keropi
darry wrote on 2022-04-29, 07:11:
This is the ultimate way , I use external mixers too ... it is the nature of DOS games to mess with volumes and sometimes even apply crazy values to the max.
So having the ability to fine-tune and mute on demand is priceless 😀
Reply 58 of 380, by darry
keropi wrote on 2022-04-29, 07:47:
Indeed, and on that note, this utility is probably worth mentioning as well MIDIto r12 (Midi and FM redirection, Mixer locking, Sound Blaster fixes) . I presume that it will work with CMI 8330 based cards as well . Have you tried it ?
Reply 59 of 380, by Kahenraz
I have a problem where most mixers don't differentiate FM synthesis well in the mixer, or it's shared with some other slider like digital sound. What often happens is the digital sound drowns out the FM, the FM is too quiet, even at max volume, etc.
What I ended up doing was pair a Sound Blaster for Yamaha OPL3 FM and Adlib compatibility with some other card for digital sound. It's a lot of extra work but it guarantees that I have full control over the music volume, and also avoids any bugs that are present in a lot of Sound Blasters with digital audio.
