Reply 140 of 368, by Shreddoc
- Oldbie
appiah4 wrote on 2022-05-28, 10:55:Here is a proper recording with the 3D Spatializer disabled: […]
For comparison:
YMF719 - Arrakeen Palace
ES1868 - Arrakeen PalaceThat took a while but I think I finally did it.. I think.. 😅
Anyway, like I said:
- ES1868 has great filtering, a soft sound and ESFM is fairly damn close to OPL3, though not exactly the same
- YMF719 appears to have a (mostly?) unfiltered FM synth so it sounds somewhat harsh and electronic, but is genuine OPL3
- MK8330 (at least to my ears) appears to have some kind of a low-pass filter that makes it sound pleasant like ES1868, and its FM Synthesis (again to my ears) indistinguishable from genuine OPL3.As a final note, MK8330 and Terratec Gold also have WAY lower background noise levels than the YMF719 (-56dB vs -47dB in my recording setup).
keropi wrote on 2022-05-28, 10:51:thanks! truth be told the original CMI driver package is not bad - it initializes the card and mixer and quits with no memory co […]
appiah4 wrote on 2022-05-28, 09:55:My recording was made with unisound and therefore 3d spatial effects, apparently. I will rerecord with official cmi drivers/mixer in an hour or so.
thanks!
truth be told the original CMI driver package is not bad - it initializes the card and mixer and quits with no memory consumption
if/when unisound implements switches for the other options it will be great but I am not sure how easy is this because there is no real tech docs for the CMI8330For now I am using UNISOUND to initialize followed by CMMIX.COM to set the mixer volumes and disable 3D, Gain and SB Mixer options.
I'm not using CMINIT.EXE because the DOS driver installer actually froze on this system during post-install testing, probably due to the same reason YMF719 cards freez when I try WSS on this system - a hardware resource issue that UNISOUND doesn't care about but the official drivers get stuck on. Regardless, this way seems to work fine 😀
Thanks a lot. It's great to get such an in-depth, real world handle upon exactly what kind of experience can be expected when directly compared with other popular cards.
This card clearly does a good enough job to be better than most, with respect to FM "accuracy" and general sound output quality, and now we can hear exactly how.
