First post, by UltimateElectronic
G'day all,
I've got a Mozart OTI605 sound card, as an interesting side note, it has a very odd pin header connector, not the traditional ISA connector, coming from the Italian OEM Olivetti (it was made in Italy). I've found that the OTI601, or at least the
drivers, seem to be more common. Are the drivers cross compatible across cards in Windows 3.1? Thanks in advance!
UltimateElectronicFun
