Reply 480 of 1732, by Baron von Riedesel
MBH wrote on 2023-04-12, 12:02:Why there are two SBEMU with different approach from different developers, both named SBEMU and in the same thread? What's the purpose? Do you plan to merge at some point? At least for me, it's confusing. Can someone explain please? Wouldn't it make more sense to work together on one codebase?
I renamed the fork to VSBHDA to avoid any confusions. And it's a public github repo now.
The reason for this fork is to have a HX compatible SB emulation, something that SBEMU isn't. It's not focused on games, and I plan to eventually remove the mpxpart, focused on HDA ( only? ).
Actually this plan was the reason why hdpmi32 with port trapping (hdpmi32i) came into existance at all...
