First post, by AngryByDefault
- Member
Hi all,
Today I got an Audigy 2 zs and I'd like to use it's gameport by attaching a breakout cable.
Since it was a rather expensive purchase I don't want to risk it by just plugging a random addon from another sound card, so I figured I'd ask here if someone could confirm that the header uses a standard pinout and it should be safe to use the connector from (i.e.) any Exel 3D CMI-8330 or similar ISA card.
I' ve been searching for a while on the forums and Google before bugging here, but this one is the only reference that I've found to the issue:
Sound Blaster Audigy 2 ZS Gameport Header
I'd feel more comfortable with some reassuring before giving it a try.
Thanks in advance!
