Reply 20 of 26, by shandavid
Played by SC8850:
https://youtu.be/aYk2w2QlCnc
Played by SC8850:
You can listen to the video above to see if the sound is more comfortable and better than other SC8850 videos.
DerBaum wrote on 2023-09-27, 08:06:Spikey wrote on 2023-09-27, 07:27:...I wish power cords...
For optimal listening pleasure i recommend gold plated optical cables.
Ironically I have some gold plated RCA cables from when I worked at RadioShack, some discontinued items I got for free. Not every cable I use is gold plated, mind you. 😉
DerBaum wrote on 2023-09-27, 08:06:For optimal listening pleasure i recommend gold plated optical cables.
Isn't gold the best light transmitting medium? 😁
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
shandavid wrote on 2023-09-27, 10:15:DerBaum wrote on 2023-09-26, 19:12:The SC8850 takes 11Watts at 230Volts. Thats 0.04782 Ampere. Our supplied voltage is AC. The assumed cable length is 2 Meter. Th […]
Our supplied voltage is AC. The assumed cable length is 2 Meter. The assumed loss is 3%. Assuming both ends of the cable have proper connection.Screenshot 2023-09-26 210738.png
The optimal cable thickness is 0.0005mm² .
Everything above that will make no difference.
In american freedom units its the same story...
These have nothing to do with sound quality
He just gave you the optimal wiring diameter for the 8850. Anything other than that is just wasting money and materials.
As long as the device is earthed properly then there should be no difference what mains cable you use.
https://www.target-earth.net
analog_programmer wrote on 2023-09-26, 16:34:Does this cable has current flow direction? 😁
Superstition aside, the SC-8850 does have a polarized C7 socket, but amusingly it was sold with a non-polarized wall plug cord in most regions. I'm assuming the reason is simply regulatory compliance, and not technical?
It'd be money, wouldn't it?
