YMF71X - disable SB?
First post, by deepthaw
I’d like to run my YMF715 with my SB16 for the bug-free UART and the IDE port for my CD-ROM drive. Is it possible to totally disable its SB support to free up resources?
Reply 2 of 5, by darry
Why not use both and use the better one, as needed, with non-overlapping resource assignments configured ?
Reply 3 of 5, by deepthaw
darry wrote on 2023-11-02, 02:46:
That’s what I’ll probably end up doing. If I could get a SB16 and GUS to coexist back in the day, this should be a piece of cake.
Reply 4 of 5, by darry
deepthaw wrote on 2023-11-02, 02:47:
I used to have an AWE64 , YMF715 and GUS coexisting, so I concur.
Reply 5 of 5, by Gmlb256
That's exactly what I did with my current retro computer which has 3 ISA sound cards coexisting: SBPro2, AWE64 and GUS. If you're using a joystick/gamepad, disable the gameport of the sound card where it isn't going to be plugged.
