Review: Sound Blaster PCI 128 (CT4810)
Reply 20 of 45, by darry
Joseph_Joestar wrote on 2024-02-16, 10:13:
Small update: I was looking over the SBPCI.INI file to see if there are any other relevant settings for DOS gaming, when I notic […]
Small update: I was looking over the SBPCI.INI file to see if there are any other relevant settings for DOS gaming, when I noticed this block:
; Switches - Self-Config, Sound Blaster emulation enable,
; Joystick enable, CD-DA enable, MM KeyBd enable
SelfConfig=true
SBEnable=true
JSEnable=true
KBEnable=false
Nothing out of the ordinary right? Well, notice how the developer's comment mentions CD-DA yet there is no such option listed below. This made me curious, so I opened SBCFG.EXE using Norton Commander's viewer and found a reference to CDDAEnable right next to the other settings listed above. Then, I added that line to SBPCI.INI so that the relevant block now looks like this:
SelfConfig=true
SBEnable=true
JSEnable=true
CDDAEnable=true
KBEnable=false
And sure enough, this made the card pull digital CD audio over the ATA interface in pure DOS! To make certain of this, I powered down the computer and physically disconnected the analog CD audio cable. Then, I powered the PC back on, started Tomb Raider and got CD music playing properly. Pretty cool, eh? If anyone's curious, here's how the card's initialization feedback looks when this setting is enabled:
Unfortunately, this isn't perfect, as there is some distortion on the CD audio during heavy disk access. Also, a CD which contains audio tracks needs to be in the drive for the card to initialize correctly while this setting is enabled. Both of these issues make me think the developers chose to hide this option for a reason. Still, it's interesting that there's a sound card which can pull digital CD audio from the ATA interface in pure DOS.
Nice find! I wonder if that option exists in Live or even Audigy DOS drivers and whether it works any better or worse.
Additionally, I wondewonder if it might work better if the CDROM was run as a single drive on an IDE port rather than as a slave like in the config in your screenshot.
Reply 21 of 45, by Joseph_Joestar
darry wrote on 2024-02-16, 14:47:
I checked the Audigy DOS drivers, but unfortunately, the .INI file included there doesn't contain any of the parameters that are used by Audio PCI cards. In fact, the Audigy's .INI seems to serve a different purpose altogether, which is to identify chipsets that aren't compatible with Creative's DOS audio emulation. Despite sharing the same roots, it seems that Creative modified the SBLive/Audigy drivers far enough that they no longer recognize Audio PCI sound cards, and don't accept any .INI parameters related to them.
I wouldn't hold out much hope, since the developers removed the "CDDAEnable" parameter by default, and they probably had a good reason for that. Also, this only works in pure DOS. If you boot back into Win9x, the card's auto-config will always erase this parameter from the .INI file.
Reply 22 of 45, by darry
Joseph_Joestar wrote on 2024-02-16, 15:15:
I checked the Audigy DOS drivers, but unfortunately, the .INI file included there doesn't contain any of the parameters that are […]
I wouldn't hold out much hope, since the developers removed the "CDDAEnable" parameter by default, and probably had a good reason for that. Also, this only works in pure DOS. If you boot back into Win9x, the card's auto-config will always erase this parameter from the .INI file.
Thanks for checking.
I don't hold out much hope for CD audio in DOS being perfect with the CDROM as single master, but it might be be more resistant to disk I/O related skips. Too bad there is no source code to this available. It might have been possible to make this feature work better.
Reply 23 of 45, by Joseph_Joestar
I've tried a few games on the SB128 using my Celeron 466 + Abit ZM6 (440ZX) system. These are just titles that I either regularly play or use for testing purposes. I don't plan on testing every single DOS game, but the list of titles that I chose should give people a decent idea of the card's compatibility. All of these tests were conducted in pure DOS 7.1. Here are the results:
  • Aladdin - works
  • Command & Conquer - works
  • Crusader: No Remorse - works
  • Dark Forces - works
  • Descent - works
  • Doom 1 - works
  • Doom 2 - works
  • Duke Nukem 2 - digital sound effects don't work, FM synth works
  • Duke Nukem 3D - works
  • Dyna Blaster - needs slowdown to work
  • Gabriel Knight - works
  • Gods - works
  • Heretic - works
  • Heroes of Might & Magic 2 - works
  • Indiana Jones and the Fate of Atlantis - needs slowdown to work
  • Jagged Alliance - works
  • Jazz Jackrabbit - works
  • King's Quest VI - works
  • Lemmings - works
  • Master of Orion 2 - works
  • Monkey Island 1 - works
  • Monkey Island 2 - needs slowdown to work
  • Mortal Kombat 1 - FM synth works, digital sound effects partially work, but sometimes cut out
  • Mortal Kombat 2 - works
  • Mortal Kombat 3 - works
  • One Must Fall 2097 - works
  • Prehistorik - fm synth works, digital sound effects don't work even with slowdown
  • Prince of Persia 1 - doesn't work, freezes on start
  • Prince of Persia 2 - works
  • Quake - works
  • Rambo 3 - doesn't work, crashes on start
  • Red Alert - works
  • Settlers 2 - works
  • Simon the Sorcerer 2 - works
  • Space Quest V - General MIDI works, digital sound effects don't work even with slowdown
  • Stonekeep - works
  • Tomb Raider - works
  • Transport Tycoon - works
  • Turrican 2 - doesn't work due to EMM386 being loaded
  • Tyrian - works
  • WarCraft 1 - works
  • WarCraft 2 - works
  • X-Wing - needs slowdown to work
Note: by "needs slowdown" I mean through utilities like THROTTLE or SETMUL. As with all PCI sound cards, game compatibility may vary based on the chipset that your motherboard uses. So take these results as indicative of the 440ZX/440BX chipset only. Also, I didn't do any extensive testing with these games. I just made sure that they start, and then played for a minute or two.
Reply 24 of 45, by Babasha
8MB ECW soundbank is not optimal, got the sound glitches in MT-32 mode with Lotus III
Need help? Begin with photo and model of your hardware 😉
Reply 25 of 45, by Joseph_Joestar
Babasha wrote on 2024-02-17, 09:20:
I'm not familiar with that game, but the MT-32 Vogons wiki page states that it requires CM-series/LAPC-I for proper MT-32 output.
Not sure if it also uses custom instruments, but those most certainly won't work on the SB128.
Reply 26 of 45, by Babasha
Joseph_Joestar wrote on 2024-02-17, 09:35:
I test this game with Ensoniq/Creative cards. 4MB ECW soundbank are nice, 8MB has distorted sounds.
Reply 27 of 45, by Joseph_Joestar
Babasha wrote on 2024-02-17, 18:33:
Interesting. It's too bad those ECW sets are proprietary, would be nice if someone could actually open them up and check the contents.
I'm just guessing, but maybe the developers wanted to cram in higher quality samples into the 8MB set so badly that they accidentally overwrote some of the MT-32 stuff.
Reply 28 of 45, by Joseph_Joestar
Another update regarding digital CD audio over the ATA interface in pure DOS.
In games like Tomb Raider, which both stream data and play CD audio from the disc, distortions do occasionally appear. Also, I did try attaching the CD-ROM on the secondary channel as the only device, and the distortions still occurred. However, in other games like Quake, which completely install their data to the hard drive, and only use the disc for playing back CD audio music, there are almost no distortions.
In short, the more a game accesses data from the disc while playing back CD audio, the higher the chance of distortions.
Reply 29 of 45, by darry
Joseph_Joestar wrote on 2024-02-18, 12:08:
TY for the extra tests. So it makes sense that this option was left undocumented.
Reply 30 of 45, by Joseph_Joestar
And another update regarding GS support in various ECW sets. I've mainly tested this with Dune 2 configured to use Roland GS for both music and sound effects. The game's intro is a good showcase for GS instruments.
  • The 2MB set seems to have very limited GS instrument support, and the effects get substituted by incorrect sounds in some cases. For example, when rockets are launching, it sounds like an old telephone is ringing
  • The 4MB set seems to lack most GS instruments and many effects that are supposed to play simply remain silent
  • The 8MB set seems to have all GS instruments, at least judging by the fact that every sound effect played correctly. Meaning, I could properly hear wind blowing, ships landing, guns firing and rockets launching during the intro
This is not a very comprehensive test, so don't take my findings as gospel. Again, without being able to open the ECW sets, it's difficult to say what's actually contained in there.
Reply 31 of 45, by Joseph_Joestar
I tried opening the ECW files using Total Commander's built-in viewer. There's a text header at the top of each file, and here's what it says:
2MB ECW
ECLW Copyright © 1999, Creative Technology Ltd.
2 MB Waveset ver 3
2MEG_R_3.ECW
4MB ECW
4 MB Waveset ver 4
4MEG_R_4.ECW
8MB ECW
8 MB GM/GS Waveset ver 5
8MEG_R_5.ECW
8 Megabyte Waveset with full GM/GS implementation
The last line in the header of the 8MB file confirms that it does have the full GS implementation. Note that there's no such line for the 2MB and 4MB files, and based on my previous tests, it doesn't look like their GS support is entirely functional.
Reply 32 of 45, by darry
Joseph_Joestar wrote on 2024-02-18, 20:41:
I tried opening the ECW files using Total Commander's built-in viewer. There's a text header at the top of each file, and here's […]
2MB ECW
2 MB Waveset ver 3
2MEG_R_3.ECW
4MB ECW
4 MB Waveset ver 4
4MEG_R_4.ECW
8MB ECW
8MEG_R_5.ECW
There is an archived copy of https://web.archive.org/web/20110819020545/ht … y/ecw/index.php
which contains some info and was previously referenced here : ECW Wavetable format available!? (SBPCI/Live)
Reply 33 of 45, by chinny22
2 reviews on the Ensonic PCI range in as many days!
About ES13** PCI card
For such an unpopular range of cards they are getting some love at the moment.
a bit out of scope of this review but I always had problems with Creative's PCI dos driver, network driver and C&C/RA in pure dos
This was on 2 different PC's, with Realtek and Intel NIC's
For a budget card I thought they were fine, dos support still been important for me at the time.
These days the cheap and plentiful supply of SB Live! does kind of make these cards pointless unless you already own one
Reply 34 of 45, by Joseph_Joestar
darry wrote on 2024-02-18, 20:55:
Interesting, so there was an attempt to reverse engineer these at some point.
I've checked the documentation on that page, but I couldn't find any new info related to GS or MT-32 support at a cursory glance.
Reply 35 of 45, by Joseph_Joestar
chinny22 wrote on 2024-02-19, 01:51:
Heh, maybe one of the retro YouTube channels will cover it as well! 😀 I have to say, despite my initial dislike for this card, it has slightly grown on me during the recent tests. The SB128 is not a bad choice for late DOS gaming, as long as you don't use its awful FM synth emulation and just stick to General MIDI.
Now that you mention it, I did notice that the Matrox MSI version of Tomb Raider doesn't work with this sound card, while the default software renderer runs fine. Not sure if it's related to your issue, but it does seem vaguely similar.
Pretty much, yeah! Especially for Windows gaming, as EAX sounds significantly better on SBLive/Audigy cards.
Reply 36 of 45, by Riikcakirds
Loading Jack R Ellis XHDD and XDVD2 ultra DMA drivers for HD and CD might get rid of the distortions.
About Rambo III not working, I have found it does work with the SB emulation but only if I use a very old PCI video card, like S3 968. Using a newer PCI or AGP card and it just goes to a black screen. I think it's something to do with newer video bios and the emulation tsr.
Reply 37 of 45, by Joseph_Joestar
Riikcakirds wrote on 2024-02-19, 18:07:
Interesting. I have never used those before, but I might give them a try at some point.
Hmm, I have mostly been using a TNT2 M64 as my GPU on this particular system. I guess I could try an S3 Trio64V+ but I'm not sure if I have any PCI graphics cards older than that.
Reply 38 of 45, by holdencars11
Were you using VXD drivers to get the nice control panel settings? I don't recall it, but its been a long time since I've used AudioPCI..
I also have a Audio PCI 3000 with the ES1370 and AKM AK5331 which seems to have 4 channel output for DS3D Quad mode, but I think SPDIF is reserved for the ES1373 based chips
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
Reply 39 of 45, by Joseph_Joestar
holdencars11 wrote on 2024-02-24, 11:37:
Yes, those are stock VxD drivers from the installation CD that came with my card. I still have the actual disc.
Interesting. I heard that some of these cards support 4 speaker surround, but my particular one doesn't seem to do that. At least there is no mention of that feature anywhere in the documentation.
Out of curiosity, did your card have a dedicated jack for the rear speakers? Or did they plug into one of the existing ports, which was then re-configured by the drivers?
