Reply 880 of 923, by sofakng
keropi wrote on 2024-04-14, 04:15:
PCMIDI ideal settings are IRQ2 and address 330 (you might need to disable ACPI and revert to APM in the MVP3 mobo bios to get back control of IRQ2)
Thanks so much for the help and explanation!
Is there any disadvantage to disabling ACPI? (I think it just enables automatic poweroff when you shutdown Windows?) (sorry if this is a bit off topic from the Orpheus)
EDIT: Disregard. I can disable ACPI in the BIOS but it still doesn't free IRQ 2. I've looked into ModBin to modify the BIOS but it looks like the option to free the IRQ isn't present (and isn't hidden). I'll just have to use IRQ 3 it seems.
Is it OK to use the IRQs assigned to the COM and LPT ports as long as I'm not actively using those ports? (or do I need to disable them in BIOS)
Reply 881 of 923, by NJRoadfan
Disable the COM ports you aren't using in the BIOS. The PC MIDI section should work fine on IRQ 3. Just make sure the IRQ is reserved for Legacy/ISA in the BIOS so another device doesn't grab it.
Reply 884 of 923, by TheFrog
Boohyaka wrote on 2024-04-28, 08:12:
Works fine here.
Thanks I figured it out *sigh*
I just wanted to download the software again and I googled the Orpheus 2, clicked on the pcmidi.eu link and I got an 404 error, it linked me to the https site and not to the non secured http site.
So anyway thank you for the reply!
Reply 885 of 923, by keropi
LT and PCMIDI boards are available again in case someone is interested 😀
Reply 886 of 923, by CHA0SHACKER
keropi wrote on 2024-05-08, 18:46:
I already ordered. Cannot wait.
AMD K6-III+ 400 ATZ @ 550 MHz 1.8V | Gigabyte GA-5AX Rev 5.2 | 256MB 100MHz SDRAM CL2 | 32GB CF Card | 3DFX Voodoo 4 4500 32MB @ 183MHz | Orpheus II LT with X2GS-SE Wavetable | Gravis UltraSound PnP (clone) with 16MB SIMM
Reply 887 of 923, by keropi
CHA0SHACKER wrote on 2024-05-10, 20:26:
Thanks for the support 😁
Reply 888 of 923, by Shponglefan
I was trying out the Orpheus II with Crusader: No Remorse and ran into an issue. During the movie sequences, the audio starts stuttering after about 10 seconds or so. It will stutter for a few seconds before returning to normal, but then will stutter again after another 10 seconds or so.
This only seems to happen during the movie sequences. In-game audio appears to be okay.
I'm running this on a Pentium 4 651 @ 3.4 GHz (see signature link for system details).
I've tested this with the Orpheus II, Orpheus II LT, and Orpheus I. I tested the Orpheus II LT and Orpheus I with both the Orpheus drivers and Unisound. This issue persists in all cases.
I also tested a Yamaha Audician 32 and AWE64 on the same platform with Unisound. Both of those cards are fine and movie playback audio doesn't have any issues.
Is there any tweaks or suggestions I can try? Or is this possibly an incompatibility with Crusader and the Crystal audio chip?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 889 of 923, by keropi
I will be testing some fresh LT boards later so I will also try the game and report back if I get the same issue
Reply 890 of 923, by keropi
I am getting the same issue - resources or install size make no difference
after applying updates for 1 time the game ran in Soundscape more (WSS from what I can tell) with better quality and no movie stutters but after this one time it never ran again like that... looks like the sound driver does something that the CS4237 does not like
Reply 891 of 923, by Shponglefan
Thanks for confirming, so at least I know it's not just me.
I don't suppose there is any chance for a workaround or updated driver or something?
Reply 892 of 923, by Joseph_Joestar
Shponglefan wrote on 2024-05-12, 22:33:
On an unrelated note, you don't want to play Crusader: No Remorse/No Regret on a SBPro compatible card. They are among the few DOS titles that actually use 16-bit sound.
You want a SB16 for optimal sound playback in both Crusader games. The difference is noticeable.
Reply 893 of 923, by Shponglefan
Joseph_Joestar wrote on 2024-05-13, 02:24:
Oh, I agree. I've played it with an AWE64 before and it does sound great.
I still wouldn't mind seeing if there is a way to make it workable with the Orpheus II though.
If that's not an option, I might try it under DOSBox with SB16 emulation and see how that goes.
Reply 894 of 923, by keropi
the only driver update the game has is the one that supposedly has better SB16 support and adds GUS and Soundscape support
too bad they did not add a WSS mode as well
Reply 895 of 923, by Shponglefan
I was actually wondering if the Orpheus driver itself could be modified. Or is that not something that would be possible in this instance?
Though I'm assuming since Unisound also produces the same result this is just one of those fundamental incompatibilities between the game and sound card.
Reply 896 of 923, by keropi
no it's not an initialization driver issue - it's a game driver issue
take for example Dynablaster - try it with a YMF card: it will produce noise and parasites but it's ok with CS
buggy game drivers
Reply 898 of 923, by CHA0SHACKER
Got mine today. Great card.
1.91 MiB
Had to fiddle with the DMAs and IRQs for a while. The final settings somehow work and I don’t quite understand why (with all these devices being on IRQ 3).
315.51 KiB
