First post, by appiah4
I was messing around with some PCI cards yesterday to choose one for an upcoming Slot A build. I was going to go for the Turtle Beach Santa Cruz but then my soft side for Terratec took over so I decided to give their DMX Xfire 1024 a whirl.
Interestingly enough, the DMX Xfire 1024 comes with a DLS compatible software wavetable that accepts up to 8MB sample files and runs with the default 8MB DLS sample set Terratec ships with it (though I don't know if it is made by Terratec or Crystal or whoever..). It is usable in a DOS Box in Windows.
DMX Xfire 1024 has a CS4624 chipset, so the Santa Cruz with the more advanced CS4630 should also have this wavetable right? Well, apparently not, or at least I can not seem to find it not on the driver CDs at the very least (It may just be that I didn't look hard enough, if the card has the same synth please let me know!).
Does anyone know if this DLS Wavetable Terratec supplied is a Crystal thing that works with all CS4624/4630 cards or a Terratec software that requires a Terratec card? Has anyone tried it and knows what it sounds like?
Reply 1 of 16, by appiah4
Apparently it's by Crystal and Santa Cruz also has it in the drivers (dumb me)
A video of recordings can be found here: https://www.youtube.com/watch?v=ZDX87rAfBLg
It sounds very pleasing if I may say so.
The DLS here can probably also be used with Aureal cards and their DLS Wavetable Synth as well. I will try to extract and share the DLS for someone to try.
EDIT: It's the same file as the Terratec, CWCDLS8.CLS so not exactly a DLS.. Maybe someone knows how to convert it to DLS? I'm probably rediscovering the wheel here but it's nice to know these things ship with a decent software wavetable nonetheless 😀
Reply 2 of 16, by MordekaiZeyo
Looks like we're stuck with the file CWCDLS8.CLS... Still no clue for opening the file. I tried in Notepad++, Sublime Text and the similar LaTeX software but unknown decoder and absolutely no hints. Yeah... I am not a programmer by the way.
Intel Pentium 3-S 1266Mhz | 512 MB DDR-400 @SD-RAM PC133 | Elitegroup P6S5AT | Galaxy Geforce 6600 GT AGP @4x AGP | Terratec Xfire 1024 PCI Soundcard with Dreamblaster X2
Windows 2000 Pro SP4
Reply 3 of 16, by binarymaster
appiah4 wrote on 2019-11-14, 05:56:
The filename suggests it's a DLS file, but its byte distribution graph rather shows that it's encrypted:
file.php?mode=view&id=188232
by Stas'M
Reply 4 of 16, by appiah4
binarymaster wrote on 2024-03-16, 14:08:
The filename suggests it's a DLS file, but its byte distribution graph rather shows that it's encrypted: […]
Anyone tried to open it in 7-Zip?
Reply 5 of 16, by binarymaster
appiah4 wrote on 2024-03-18, 06:59:
It was the first thing I tried, thought it could be compressed, but it didn't open it. Also tried STUNS without success.
by Stas'M
Reply 6 of 16, by binarymaster
The decryption algorithm seems to be located in the cwcwdm.sys driver, in the function where it opens registry key "SYSTEM\CurrentControlSet\Services\cwcspud\CS461x\Algorithms\WaveTable" and reads "SampleSet" value from there, which contains the path to CWCDLS8.CLS.
Reversing will take some time, but from the first look it seems to be decoding data blocks of size either 20 or 24 bytes long.
Also, the driver doesn't contain any known DLS format-specific magic constants, so the sound bank format is likely custom.
by Stas'M
Reply 7 of 16, by binarymaster
binarymaster wrote on 2024-03-18, 19:40:
So... I was looking at the wrong driver file 😁 First of all, cwcwdm.sys expects unencrypted sound bank file, and it indeed doesn't support DLS. Instead it uses CWCWTSMP.DAT bank file, which has custom headers "CS4610v1.0" and "MSAv1.0". Some structures of this file are in fact XORed, so I thought it might have something to do with the CLS file encryption.
But, looking at the another driver file tbcwdm.sys finally revealed the encryption algorithm! Entire CWCDLS8.CLS file is encrypted with XOR and bit swapping, taking into account previous XOR byte value.
Let me post the decrypted file, I don't know if there's just one that file, or different drivers may have different versions of the sound bank.
- input file cwcdls8.cls
md5: CBD7790F10A05DCA429CEA8ECA03B4CF
sha1: DEEA7B5BA1AD483B456712A4D24A78C5FE1C6766
- output file cwcdls8.dls (download)
md5: 20D3159968915AB4575CB8DA7A805ADD
sha1: 0802C56A958F6D0FA959C2FB5DA7271A3398A56B
I will post the decoder with source code a bit later when I finish polishing and testing it.
by Stas'M
Reply 8 of 16, by appiah4
binarymaster wrote on 2024-03-18, 23:53:
So... I was looking at the wrong driver file :D First of all, cwcwdm.sys expects unencrypted sound bank file, and it indeed doe […]
Oh wow, great news. Now we need to load that dls onto a softsynth and see if it works 😁
Reply 9 of 16, by binarymaster
appiah4 wrote on 2024-03-19, 07:50:
I've published repository on GitHub:
https://github.com/binarymaster/cwcdls8-decrypt
You can also try it directly in your browser: https://jsfiddle.net/r0az7vhe/
Tried the resulting DLS sound bank in the Winamp / Nullsoft MIDI Player, doesn't sound as good as in the YouTube video that was published here. If you have a better suggestion for the software wavetable MIDI synthesizer with DLS support, let me know. 😀
by Stas'M
Reply 10 of 16, by RetroGamer4Ever
FluidSynth has limited DLS support, but I have no experience using DLS with it. Unfortunately, outside of audio composition programs that can load DLS files - I'm not sure there are any left at this point, because the format disappeared from the market in the 2010's - I'm not sure there's anything beyond the Microsoft Wavetable Synthesizer, which requires all sorts of tomfoolery to use additional DLS files with. Back in the day, there were a few soundcards that used DLS-backed soft-synths and could take encrypted/unencrypted DLS packs beyond whatever one shipped with the card, but those are long gone.
Reply 11 of 16, by appiah4
binarymaster wrote on 2024-03-19, 16:30:
I've published repository on GitHub: https://github.com/binarymaster/cwcdls8-decrypt […]
Thank you for the github repository!
Aureal Vortex 2 (Monster Sound MX300) cards come with a DLS Softsynth off the top of my head.. I don't know a nonproprietary softsynth that uses DLS though. Paging @Falcosoft as the local softsynth guru 😁
Reply 12 of 16, by zaphod77
apparently there's a sony dls softsynth which is bundled with a number of daws, such as acid pro.
There might be a stand alone version somewhere?
Reply 13 of 16, by RetroGamer4Ever
No, there's no stand-alone version that I can find evidence of and it's apparently a Sony licensed GS-compliant DLS synth software-tied to their Acid DAW software offerings, though the stuff I found says it's with the older versions and may not be with the latest version.
Reply 14 of 16, by Rawit
*Edit: removed broken link, valid link (30 days) in my post below.
This is awesome! Here is the DLS converted to SF2 with Awave Studio (no tweaks or changes made, straight conversion):
YouTube
Reply 15 of 16, by appiah4
Link seems to be broken 😔
