Reply 200 of 3175, by shock__
I'll be able to do that myself, in a week or two when I get access to my pile of waste soundcards, but if someone else in the meanwhile could help out, um yeah, that would be terrific.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 201 of 3175, by dogchainx
I might have a source of a lot of ISA sound card brackets. I'm waiting to hear from him if everyone is interested.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
Reply 202 of 3175, by Marmes
I can ask someone to make it but I bet there is also someone in Germany that could do it
Reply 203 of 3175, by shock__
Make what exactly? Custom brackets? I bet that wouldn't pay out pricewise.
[Z?]
Reply 204 of 3175, by HighTreason
Use panel mount 2.5mm jacks and just drill out blank brackets. Like these;
This is how some Chinese manufacturers do it, I have a fer Envy24 cards that were made this way.
Reply 205 of 3175, by shock__
I like the donor bracket idea better ... those can usually be obtained for cheap and cause me virtually no additional work.
Drilling out blank brackets would be something every reciever of a card would have to do it own their own.
[Z?]
Reply 206 of 3175, by bjt
I would be interested in one of these, got a free ISA slot to fill with something cool.
Reply 207 of 3175, by shock__
The skirt has been lifted (as Dave Jones would say)
Worked out quite well, from what I've seen no pads have been damaged - so the card can still be restored (just looks messy because I didn't clean up the old solder yet).
[Z?]
Reply 208 of 3175, by Marmes
will you lift the rest? There might be some more traces below resistors , capacitors and other ics.
Reply 209 of 3175, by shock__
I'm quite sure I got every trace connected to the passives.
I might lift the smaller ICs at one point, as I "beeped" them through and am pretty sure I got everything right, but once I get to the schematic errors might occur.
[Z?]
Reply 210 of 3175, by CHiLL72
Nice job!
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 211 of 3175, by shock__
First major milestone reached: Everything redrawn and the design passes the DRC (design rule check).
If I wanted to be cheap and lazy, one could consider the project finished ... but now it's off to reversing the actual schematic, doing a prototype to confirm everything works and then improve the design/specs.
[Z?]
Reply 212 of 3175, by Thraka
What a cool thread and cool set of guys. I love it! I always wanted an ultrasound when I was a kid. We could only afford a Thunder Board.
Reply 213 of 3175, by shock__
Thanks
On another note ... has anyone ever successfully dumped the 1MB ROM of the GUS PnP? Not asking for an image, but I realized there might be a small issue (nothing that can't be solved).
[Z?]
Reply 214 of 3175, by hard1k
As far as I know (and judging from zero replies in my GUS related threads) no known attempts have been identified so far. What is the issue you're talking about?
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 215 of 3175, by shock__
Pins on the IW78C21M1 are probably scrambled in a unusual pattern not widely supported on EPROM programmers.
Not an issue at all since I'm cool with soldering airwires (to get the chip dumped) ... but one would have to decide/test if the use of standard ROMs would be feasable then.
[Z?]
Reply 216 of 3175, by hard1k
That's where a dead GUS PnP will be helpful - as I mentioned before, Gravis has provided for a standard (tbc!) DIP-packaged ROM having its pins wired up to the IW78C21M1 making possible to revert its pinout.
AWE64 Legacy
Reply 218 of 3175, by hard1k
Holy cow, a GUS PnP prototype with actual DIP socket and some 2-chip ROM add on board installed!
I would love to have that...
If I'm not mistaken, there are two paired ROMs on a converter board. I guess, the solder points for that DIP socket on production boards are standard - why would Gravis invent their own proprietary pinout?..
But that still has to be confirmed.
AWE64 Legacy
Reply 219 of 3175, by Marmes
Why would they be?
ls373 is used to buffer rams and roms, so getting pinouts for reading is not hard, they are not being scrambled 😀
