First post, by JohnMLTX
Hello all!
I have a Unisys CWD4002 486 PC with a Sound Blaster Vibra 16 in the ISA slot.
I have set up MS-DOS 6.22 on the computer, and everything is working normally there. When I was first setting it up, I managed to get the sound card installed and working, but after some other tweaks and changes (including Phil'sComputerLab Starter Pack), it's not working. When I go to c:\sb16\diagnose.exe, none of the four addresses work, and the sound card can't be detected.
Same situation if I go to install it again. For whatever reason, between last Thursday and Saturday, I did something that made it angry.
Any ideas? Maybe a fresh DOS install?
Thanks!
