Reply 60 of 703, by Maraakate
- Oldbie
wrote:Another model to add to the list: […]
- Ego-Sys (now ESI-Audio) WAMI BOX
Dream SAM9407 (same chip used in the Terratec EWS64XL, Guillemot Maxisound Home Studio Pro 64 and a couple of other cards)
Sound Blaster/Pro, WSS, General Midi and MPU-401 in Win95/98/XP/2000.
16MB of onboard RAM for samples and soundfonts.
Linux drivers are also available.
A quote from the manual:
The control panel is the central control unit of the WAMI BOX. It contains firstly the analog mixer wich mixes the various audio signals, and feeds them either to the output or the synthesizer for further processing. Switching of the various signal paths also takes place here: the signals are switched as required for the many varied tasks of the WAMI BOX. When the WAMI BOX is started for the first time, the mixer is in a games-compatible mode. In this mode the card is fully compatible with Soundblaster, Soundblaster Pro and Windows Sound System.
Using this setting, DOS games can be played with GM/GS sounds or older FM sounds with effects, four-channel playback and V space.The card can also be fully reconfigured, however, for example to make hard disk recordings of the best possible quality with digital inputs and outputs.
The SB/Pro emulation work fine but doesn't offer OPL2/FM synth music, only sound effects. However the games tend to slow down (tested with Doom, Duke3d and Descent in WinXP) and the digital sounds produce some clicking. The GM support is flawless though, and with the available RAM you can put a decent quality soundfont.
The drivers are a bit messy, the latest version is incompatible with the control panel software, and the older versions make the system unresponsive.
Full specs (quoted from the website):
- * 20-bit Analog to Digital Converter
* 20-bit Digital to Analog Converter about 98dB dynamic range
* Analog 2 In / 4 Out -10dBV unbalanced with Gold-tipped RCA jacks
* S/PDIF Coaxial & Optical Digital In/Out
* Real-time Hardware Sample-Rate Converter(48 to 44.1)
* Mic Preamp with effects
* Gold-tipped 1/4" jacks Mic Input
* full LED Display; 9 large Activity Indicators
* 32 Channel MIDI Operation; 16 ch Internal and 16ch External
* Multiple sample rates - 32kHz, 44.1kHz, 48kHz
* Full Duplex: 2 Ch. Record/4 Channel Playback simultaneousely
* Uses standard PCMCIA socket - DMA Channel not required
* 16 MB onboard RAM for Synth & Sampler
* High perfomance Audio DSP based Internal Mixer
* 17 Delay lines for resonance-free stereo effects
* Up to 64-voice, 16 multi-timbral professional sampler
* MPU-401 (UART)1 In/1 Out MIDI Interface
* Frequency Response: 20Hz - 20kHz
* Supports Windows MME, DirectSound, ASIO driver
* Windows 95/98 compatible
* Windows XP/2000 supported with limited featuresOfficial website:
http://www.esi-audio.com/products/wamibox/
Linux drivers:
ftp://ftp.alsa-project.org/pub/datasheets/egosys/
http://www.anime.net/~sam9407/
http://sam9407.sourceforge.net/I haven't made any progress on the ESS1688 support in NT4.0, managing resources in NT4 is a nightmare...
I just foudn one of these finally awhile ago. Have you tested this on Win98SE? Does it work fine with SB emulation there? What drivers/combo do I need? I see they are available still at http://download.esi-audio.com/?w=esi&p=27&g=9&l=en
