Reply 80 of 567, by Jo22
- l33t++
wrote:^ the OPL2LPT TSR needs a 386 cpu to redirect the AdLib commands to the LPT port so a 286 machine just won't work...
plus it would be really slow if it did, that command redirection does take cpu time.
That's right, of course. But what I wonder - Why using any re-direction at all ?
Can't these commands just be watched and duplicated (mirrored) instead (to make it work on a 286, for example) ? 😀
Writing data to port 388/389 shouldn't cause any harm even if there's no actual hardware to listen to it.
