Internally routing one sound card's output to another?
Discussion about old sound cards, MIDI devices and sound related accessories.
Postby appiah4 » 2018-1-12 @ 08:34
I have several builds where I have one card for Win9x and one card for DOS, and usually the Win9x card's Line Out is externally routed to the DOS card's Line In. So essentially the DOS card is a noise generator passthrough. I do this with an external audio cable, which is messy. I was wondering if this can be done internally? Maybe I could route the DOS card's output to the Win9x's AUX or TAD headers somehow? Anyone have such a setup and how does it work?
1989:A500|+512K|ACA500+|C1084S
1992:HIPPO-VL+|DX2-66|8M|GD5428|CT2290
1995:PCI597-1|P133|32M|Trio64|V1|CT3980/2M|S2
1998:S1573S|K6-2/400|64M|RagePro|V2/SLI|CT4500/32M
2001:GA-6OXT|PIII-1200|512M|GF3Ti200|MX300
2004:K8V-D|3200+|2G|X1950P|SB0350
User avatar
appiah4
Re: Internally routing one sound card's output to another?
Postby derSammler » 2018-1-12 @ 10:42
Many sound cards have headers on the PCB directly beside the audio jacks. They provide the same signals than the jacks, so you can use them as well. And the cool thing is that they get disabled as soon as you plug something into the jack.
What sound cards do you have exactly?
derSammler
Postby appiah4 » 2018-1-12 @ 12:18
derSammler wrote:Many sound cards have headers on the PCB directly beside the audio jacks. They provide the same signals than the jacks, so you can use them as well. And the cool thing is that they get disabled as soon as you plug something into the jack.
What I have at hand are:
Creative Sound Blaster 16 CT2290 Creative CT1745A ISA
Creative Sound Blaster 16 CT2890 Creative CT2504-CQ ISA
Creative Sound Blaster 16 CT2920 Creative CT1745A ISA
Creative Sound Blaster 16 CT2940 Creative CT2502-SDQ ISA
Creative Sound Blaster 16 CT2980 Creative CT2502-SDQ ISA
Creative Sound Blaster AWE64 Value CT4500 Creative EMU8011-01 ISA
Creative Sound Blaster AWE64 Value CT4520 Creative EMU8011-01 ISA
Creative Sound Blaster PCI 128 CT4750 Creative CT5880-DC0 PCI
Creative Vibra 128 CT4810 Creative CT2518-DBQ PCI
Creative Sound Blaster Live! Value CT4780 Creative EMU10K1-JFF PCI
Creative Sound Blaster Live! Player CT4830 Creative EMU10K1-NDF PCI
Creative Sound Blaster Live! 5.1 SB0100 Creative EMU10K1-JFF PCI
Creative Sound Blaster Audigy 2 ZS SB0350 Creative CA0102-ICT PCI
Creative X-Fi Xtreme Music SB0460 Creative CA0107-PAG PCI
Edison Gold 16 Rev3.2B ESS ES688FC ISA
Genius 0207000 V2.0 ESS ES1868F ISA
Best Union MF-1868 REV:3.1 ESS ES1868F ISA
Formosa MPB-000074 Ver:1.1 ESS ES1868F ISA
Best Union MF-1869 REV:2.1 ESS ES1898 ISA
(Noname) ESS Solo-1 ESS ES1946S PCI
S-Link SL-41A ESS Solo-1 ESS ES1938S PCI
Yamaha SM718 Rev:2.00 Yamaha YMF719B-S ISA
Zoltrix Audio Plus 6400 3D PnP (AV309) Crystal CS4232 ISA
Diamond MX300 Aureal AU8830A2 PCI
Terratec 512i Digital ForteMedia FM801-AU PCI
I would like to route one the PCI and/or ISA chips with FM synthesis through PCI cards that have wavetables in Win9x or vice versa. So say an SB16 through an SB Live!, an ESS Solo-1 through an Audigy 2 ZA, or the other way around.
User avatar
appiah4
Postby Kamerat » 2018-1-12 @ 16:17
I once routed the line out of a Terratec ESS Solo-1 to a CD in or AUX in header of a Turtle Beach Santa Cruz. The Solo-1 card had internal headers for all external sound connectors. Used a cable for CD audio and had to rearrange the wires of the connector going to the Solo-1 as it differed from the output of a CD-ROM drive.
User avatar
Kamerat
Postby RJDog » 2018-1-12 @ 22:19
I have a Yamaha 718S and it has the solder positions for a header behind each external audio jack... it would be easy enough to solder in a small header and use a CD audio cable to route its line out to another cards CD or AUX in.
RJDog
Postby appiah4 » 2018-3-14 @ 15:21
Apologies for resurrecting this old thread of mine, but I'm at a loss. I have acquired a Terratec 128i TTSolo1-S for this purpose, as it comes with pins for audio in and output jacks:
Now, Routing the Line Out from the TTSolo1-S to an SB Live! would be a piece of cake - just route some dupont jumper cables from the Line Out to SB Live!'s AUX In and voila. However, this is not ideal because it would require initializing the Live! card under dos and potentially having to set up the mixer. So ideally, I would like to route it the other way around.
The problem is that on most Live! cards I can't find a single line out pin. I've looked into the idea of routing from AUD_EXT but that seems to be digital only. That leaves me with the option of routing to or from the front panel connector found on some Dell OEM Live! Value cards, one of which I happen to have.
The white connector on the top edge I believe is the front panel connector, but I can not for the life of me find the pinout so that I can route the headphone out of the card to the Line In of the TTSOLO-1. Does anyone have the pinout for this?
User avatar
appiah4
Postby Jo22 » 2018-3-14 @ 15:46
appiah4 wrote:Apologies for resurrecting this old thread of mine
No worries, it's not even half a year old. Besides, its your thread.. :)
appiah4 wrote:The white connector on the top edge I believe is the front panel connector,
I'm not certain, but I've found another SB card (Audigy 2 ZS) with such a header.
If the connector is the same. I don't see why it shouldn't be compatible (wouldn't be logical to do that).
Yet, it is Creative we talk about.. Maybe they made it extra incompatible just to annoy users ? ;)
https://audigy2zshowto.blogspot.de/2005/05/warning-you-can-damage-or-destroy-your.html
User avatar
Jo22
Postby Tiido » 2018-3-14 @ 16:15
I have just soldered wires directly to some nearby filter capacitors and route the output to CD-ROM input of another card. Normally I use one of those small white connectors that I snip off from regular CD-Audio cables, perfect length for card to card stuff.
User avatar
Tiido
Postby appiah4 » 2018-3-14 @ 23:16
This seems to be super useful, thank you!
User avatar
appiah4
Postby Plasma » 2018-3-15 @ 00:32
I recommend just using an external mixer, especially if you have multiple computers.
Plasma
Postby appiah4 » 2018-3-15 @ 04:53
Plasma wrote:I recommend just using an external mixer, especially if you have multiple computers.
Not an option with limited work space. I will rote Pins 1 2 and 3 to LGR on the TTSolo Line In. This ought to worknfine.
User avatar
appiah4
Postby appiah4 » 2018-3-19 @ 21:56
Proof of concept: Routed OEM Live!'s front panel connector's headphone pins to Solo-1 card's CD-ROM Input. The Speed-Link Solo-1 card will eventually be replaced with a Terratec 128i TTSOLO1-S soon, then I ca route the headphone out directly to Line-In and the CD-ROM audio ca also be connected straight to the Solo**1. The system will use the Solo-1 in DOS and OS2/2, both cards win Win98 and Win2K.
User avatar
appiah4
Postby matze79 » 2018-3-22 @ 13:38
Whats the benefit of having two PCI Cards ?
DOS Audio support ?
matze79
Postby appiah4 » 2018-3-22 @ 13:54
matze79 wrote:Whats the benefit of having two PCI Cards ?
DOS Audio support ?
Indeed. I use the Solo-1 for OPL3 and MPU-401 and Live for .SF2 MIDI Synth
User avatar
appiah4
Return to Sound
Who is online
Users browsing this forum: No registered users and 5 guests
