First post, by darry
The card is an Audiotrix 3D/XG and works fine under pure DOS as an SB Pro and a WSS . IRQ settings match between DOS and Windows (as far as I can tell, I assume the IRQ DMA ordering matches that in Init3dxg.exe) . driver is the version 1.0 WDM driver provided by Mediatrix (already tried re-installing the driver). Test programs were Duke Nukem 3D setup (finds an IRQ or DMA conflict) and Doom 1.9 (no sound effects) .
The same system also has an AWE64 that works fine in the command prompt and a GUS 3.73 that has no drivers installed in Windows
There are no IRQ/DMA conflicts (between either of the 3 cards).
I seem to recall it working before, is my memory playing tricks on me ? Am I missing something ?
