Reply 100 of 579, by lolo799
wrote:Is there any practical use for an AD-AJ1 with out the MD-8X music tower?
The service manual says this, so it should appear as a wavetable in Windows 9x Multimedia control panel, if you have the drivers...
MIDI recordings can be played back with high fidelity sound due to the use of a Wavetable sound source. […]
The “Wavetable sound source” used to play
back sounds is based on the data from samples
of actual instrument.
You can play MIDI files easily just by inserting
the card without needing to connect any
external sound source.MIDI file and WAVE file playback are possible
on systems using Windows.
You can play music with MIDI files using other
applications. You can also play the WAVE files,
which are Windows standard music format.
Do you have the card? A picture would be great, and a dump of the floppies too...
The AD-AJ3 service manual says this instead:
You can play MIDI data easily by connecting this PC card to an audio system that has an optical digital input terminal, using […]
digital input terminal, using an optical digital
cable. No external sound source is needed.
That makes the AD-AJ1 actually better, adding a wavetable board in your laptop that probably only has a FM synthesis option for MIDI music by default, and not needing an audio system with a toslink input to hear the music.
wrote:hi! i have a manual + original FloppyDisk from Sharp AD-AJ3 […]
hi!
i have a manual + original FloppyDisk from Sharp AD-AJ3>>>Sharp_AD-AJ3.rar<<< 68 Mb
/FDD_WinImage/Sharp_AD-AJ43_winimage.imz --- Winimage of Original Flopy-Disk
/FDD_Disk --- files from Flopy Disk
/Manual_Sharp_AD-AJ3 --- Manual English only
Very cool! Thanks!
The AD-AJ3 card uses the EMU 8000 chip, like the TDK cards.
I suppose the AD-AJ1 does too.
