TNDLPT : Tandy Sound on parallel port
Reply 80 of 173, by PoV
Awesome! I was just about to order a bunch of your parallel sound-cards for a project (writing sound code for a dos game, and I need to travel light). I'm really looking forward to this one. 😊
Mike Kasprzak | twitter
Reply 82 of 173, by dreamblaster
lvader wrote:
Any news on a release date for this? I’m holding off a couple of other purchases while I wait.
Hey, don't hold your breath !
Hardwarewise I have some prototypes ready, with the new 'muting at bootup' feature.
but still needs more TSR debugging and testing.
Feel free to PM me if you are interested in early access.
Thanks for your support !
Reply 83 of 173, by matze79
whats the difference beetween the new and my old prototyp ? 😀 maybe i can add the "change" to the pcb.
Reply 84 of 173, by dreamblaster
The new PCB has an optocoupler for interrupting the power to the chip, until it is initialized by the TSR.
Reply 85 of 173, by matze79
so the new tsr will still work with my prototyp ? 😀
time to try it 😁
EDIT: TSR loads, silencing works. but then no sound anymore.
i used EMM386. Seems EMM386 is still not working ? 😀
Now trying QEMM.
EDIT: QEMM is still fine 😀
But still slow on LowSpec Computers.
-> 386SX 16/20/25
Reply 86 of 173, by matze79
https://www.youtube.com/watch?v=66oqgOt0BSw
Tandy LPT Soundcard running with QEMM386 free Driver, still Experimental.
There still glitches, some delays.
Reply 87 of 173, by matze79
QEMM386 free TNDLPT Driver is in works, but its still experimental:
https://github.com/JKnipperts/TNDY
Reply 88 of 173, by dreamblaster
TNDLPT revision on its way, with huge thanks to Matze79 for the help with a muting solution !
preliminary device view : https://youtu.be/70jKmkNw2Wo
brief test (not final) : https://youtu.be/G-YbB-ANSp0
If you developed software for TNDLPT, please add this initialisation :
Pin CE must be 0 and Reset must be 1 for at least 100ms at init, to unlocking the mute state after startup.
This should be backwards compatible with older TNDLPT.
Reply 90 of 173, by dreamblaster
Benedikt wrote on 2020-03-07, 20:25:
Can you summarize the overall programming technique for the TNDLPT?
Most importantly: How do I enable it and how do I write a byte?
For what development environment ?
Maybe should make a small 'programmer's guide' (it will take some time)
Reply 92 of 173, by pdw
Benedikt wrote on 2020-03-07, 23:13:
I am mostly interested in the sequence of instructions that is equivalent to "out 0c0h,al" on a Tandy, because that is presumably the biggest difference.
The equivalent is something like this:
  int lpt_stat = lpt_port + 1;
int lpt_ctrl = lpt_port + 2;
outp(lpt_port, cmd_byte);
outp(lpt_ctrl, 0x0C);
int wait = 24;
while (wait > 0) {
if ((inp(lpt_stat) & 0x40) == 0) {
break;
wait--;
while (wait > 0) {
if ((inp(lpt_stat) & 0x40) != 0) {
break;
wait--;
outp(lpt_ctrl, 0x09);
(It's long, because we need to explicitly wait until the sound chip is done processing the command. That's hidden and implicit on the Tandy.)
Reply 93 of 173, by matze79
For unlock, Pin 17 and Pin 1 should be in this state:
139.28 KiB
GPL-2.0-or-later
I using ATTiny13 AVR for unlocking/muting and control LEDs.
Muting is done by using ByPass Pin of LM386.
Reply 94 of 173, by rmay635703
As I try to follow through threads here
I really wish folks would never use 3rd party hosting, half the threads are incomprehensible because of this image in place of every photo
42.21 KiB
Reply 95 of 173, by matze79
yeah that really sucks, it would be great if vogons disables external images and forces users this way to upload them here.
Easy unlock for new TNDLPT:
debug.exe
-o 37A E5
Reply 96 of 173, by Benedikt
pdw wrote on 2020-03-08, 14:31:
The equivalent is something like this: […]
int wait = 24;
while (wait > 0) {
break;
wait--;
while (wait > 0) {
break;
wait--;
That looks simple enough. Thank you!
Reply 97 of 173, by dreamblaster
a small amount of TNDLPT solder kits will be available soon,
pm me if interested, to receive one of the first kits.
Reply 98 of 173, by dreamblaster
Here's a photo of the most recent TNDLPT prototype.
885 KiB
Now I am waiting for the black color pcb's to arrive
