Reply 140 of 492, by Revolter
ruthan wrote:
Reports are actually mix bag
Not at all: Kamerat told us he hadn't tested the WBDMA modes, and dr.zeissler had reported about the games I already listed as not working in DOS even with the WBDMA treatment (the Pinball series works through FM mode, so they are non-problematic in my book) - and I'm not sure what his intention was.
ruthan wrote:
for you its working (i dunno with which values)
The value I've used is "111" - the same as on the picture. The list is translated as follows: all games fail in TDMA, "Windows" means WDM Solo-1 drivers, and "WBDMA" means "111".
ruthan wrote:
i dont care about Win98, its running fine even on much faster machines
We're talking different stuff here, then 😀 I don't care about the barebones operating system either - it's all about the total number of games this card can run with proper sound using Windows and DOS environments.
Celeron 800@1066, 512MB, GeForce2 MX AGP/GeForce 8400GS PCI, ES1938S/Dreamblaster S2, DOS 6.22/Windows 3.11/Windows ME/Windows 2000
Reply 141 of 492, by dr.zeissler
But they sound BAD in adlib, PD1 do not work in adlib, PD2 works in adlib, PF do work with adlib but strange sweeping noise is audible. So only PD2 is relatively fine.
If you have heared PD2 with GUS you don'tz want to play it with adlib and a PCI-Soundcard.
Reply 142 of 492, by ruthan
Ok what about SB and Adlib settings, which games are working with Adlib only? And what is exactly Windows value - Does it mean that pure DOS wasnt tested, or that is not working?
Win 98 - for me Win98 means - native DirectSound games, games which are not working in pure DOS, if sound card has Windows 98 drivers, they are DirectSound compatible, so they in 99% just working.. And for example SB Audigy (Win98 ones) is working with PCIe-PCI bridge in Windows 98 - on everything on which is possible to install Win98 - it worked on AM3 boards, X99 boards etc.. i didnt tested it personally, but people installed Win98 even on Z170 board..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 143 of 492, by ruthan
I tried magic values:
- i just ran ESSinit script (with value which i though that would be right ones), no ESS driver loaded at all, no autoexec, no config.sys part
- with loaded driver is sound card on my machine detected at IRQ7
- i set all IRQs to 7 to all, legacy and new, midi etc.. and set blaster variable too
- i tried few not working games with original drivers, no luck
- i tried all WBDMA values
- all was tested with SB mode, no Adlib
- because of MB compatibility limitation, im using JEMM (EMS mode)
- music is always fine and was before with loaded driver, problems are with FX
  1. Doom 2 can be run only with DOS32A, otherwise some registry errors, i heard only constant unwanted noisy sound..
  2. Blood - i can now detect SB, i setup, sound samples are working, when i run game i get black screen crash, reset.. I tried DOS32A too, no luck.
  3. Quake 1.0.8 - There is constant noise load sound, but i heard also much more silent in game sounds
  4. Carmageddon - again load constant noisy sound..
  5. Descent 2 - i hear again constant noise sound (clicking), but there some in game sounds, but i would say 50% of them..
Could someone pleas check my *.bat if values are set properly?
ESSINIT.txt
Reply 144 of 492, by Revolter
Yeah, apparently, the sound engine in the Pinball games was made to output sound through anything that could act as a DAC. I woun't be surprised if there was an option to use the PC speaker for outputting digital sound 😀 But I think the onboard FM is still better than having to use an additional DAC such as a Covox specifically for this task.
That is strange - it does on my machine. Have you tried using the standard EMM386.EXE instead of JEMM? If it freezes the computer - try using the following switches (ruthan, you can also try this line in your config.sys to see if it will fix your EMS situation):
DEVICE=C:\DOS\EMM386.EXE RAM I=B000-B7FF
No games in the list are Adlib-only - they all work in SBPRO mode. The only titles I know of that can only use Adlib and not SB: Rise of the Dragon and the aforementioned Pinball series.
I've tested each game in both the pure DOS 6.22 and Windows Millenium; when it only has "Windows" mentioned - it means that it does not output sound (or has severe problems with it) in pure DOS, but it does in Windows (and only with in-built WDM drivers, because the VxD drivers have the same compatibility as the DOS driver's TDMA mode). When it has both - then it works in both DOS and Windows. Some games only work properly in DOS, because they cannot run in Windows at all.
That's how it is supposed to work: no drivers are required, since they are essentially just for switching the PCI registers of the card - which is what this batch file's purpose 😀 The main difference is that now you have direct control over the settings - something the standard "drivers" do not allow.
I can see that you have changed some values "just in case", right? I'd recommend only changing those you are certain about, like the target SB IRQ and DMA emulation type, and leaving others default. Try the attached one (it only switches the IRQ to 7 instead of the default 5, and is enabling the "111" WBDMA).
P.S. I actually gave the Pentium 3 computer that was used to create this compatibility list (so I can no longer update it) to a good friend. But I did replace it with a Pentium 133 (430VX), and I can tell you guys that ESS Solo-1 is working there like a charm (in plain old TDMA mode, no less!), not a single troublesome game encountered. If I was told that this PC has an ISA card inside, and not a PCI one - I wouldn't notice the difference without actually inspecting the hardware list 😀 So it really comes down to the chipset.
Reply 145 of 492, by ruthan
This line, can give it only more conventional memory, its cant fix such problems, BTW i can break some text modes, B200-B7FF is safer, but for sake of my mind, i tried it, its the same. My guest is that change frame parameter would have better change of success (but everytime where is had problem with frame or i parameters, ems started and reported problem.. it should not freeze like that), if problem is EMS autodetection. But i did important discovery, moment ago, i try ATI Mach 64 PCI as primary video card and EMS without any parameters is working fine. So there some problem with Geforce 6600 AGP with combination with this board and EMS, card is fine for sure, i used it for years and removed it from other computer + I tried before multiple AGP and PCIe cards before os its not only Nvidias problems. That 4core-Vsta MB is picky i tried Trident PCI videocard and S3 Virge.. and Trident freeze at boot screen and S3 Virge no picture at all.. Note im not entire sure that these 2 are ok, i tried tem in X58 there they are not working too, but there is HP BIOS, i have try them somewhere else, my cousin tested them and claims that there are working, but he is a bit autistic(asperger):) Update: I tested S3 with i865, its working fine, so its incompatibility.
Ok good to know, when looking on you list: Carmageddon, Doom 2, Descent 2 and Quake too, only Blood shouldnt.
Not intentionally, but true is that i edited file on modern Windows, because didnt know that Dos rendering of some strange characters would be so nice and there could be some typo.. I just wanted to change IRQ for 7, DMA for 1 and set WBDMA.
Such results is expected, try hard ones - Turrican II, Ishar trilogy (no Adlib pleas) and Darklands, that would be interesting.
Thanks, i will test me file.
Reply 146 of 492, by dr.zeissler
ExtremePinball is beside Turrican2 a good test.
Reply 147 of 492, by ruthan
Ok i tested new ESSinit:
QEMU + JEMM - same results
EMS with ATI MACH 64 - Doom 2 - no fx, noisy sound, Blood - is running no FX, Descent II is the same, Quake I + Carmageddon - still same noise.
So still nothing.
Reply 148 of 492, by Revolter
And... they all worked, except Turrican 2. Pure DOS, standard driver and SB mode. Ishar 3's sound init is apparently speed-sensitive, so I had to slow down this beast of a processor in order for it to work in this game 😀
It turns out this Pentium 133 rig can be a good platform for verifying whether or not the game can play ball with ESS Solo-1 at all, so you are welcome to ask me to check it for you if in doubt.
Reply 149 of 492, by ruthan
Results is nice for owners or older machines, i didnt expect good results with Ishars with PCI soundcard.. What is error with Turrican II?, from my experience its working only in realmode (himem only).
For us with modern chipsets is still winner Yamaha or Aureals.. i would recommend ESS Solo for reasons listed above in this thread. Yamaha is less hassle, but limited to EMS.Aureal is more hassle bad FM, but could be tuned through wavetable header for games with General midi support. Rayer has some interesting news about Yamaha tunning, but its secret for now:)
Reply 150 of 492, by dr.zeissler
I will do a projekt with this Mobo in the future. Don't know when but I will do it: M6VBE-A https://www.flickr.com/photos/94839221@N05/23 … 57662872568392/
Afaik should it be possible to use a Tualatin with a S370 Adapter with this chipset. The Onbord Solo1 should work fine beside the known problems with some dos-soundengines.
btw: the manual lists WSS-compatibility, so the problematic games like Turrican should work too.
Reply 151 of 492, by MKT_Gundam
Is the VIA KT600 chipset compatible with pci like the EnsoniqSb Live and Aurel vortex?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 152 of 492, by gdjacobs
Yes. The newer VIA chipsets generally don't have problems with PCI sound like the VT82C686 series.
Reply 153 of 492, by ruthan
So compatibility info which could be handy again from mighty one - Phil, its ESS1868 rewiew, but he show that ESS support something what is called ADPCM and even ISA Yamaha 718 doesnt and there is sound example for Yamaha, i have exactly same problem with newer Yamaha in this game and there are probably more games which need this.. I would be interesting to discovered if Aureals and ESS Solo-1, SB !Live etc, have or havent this feature.
Reply 154 of 492, by gdjacobs
ADPCM is used fairly rarely. Two titles which do use it are Duke Nukem 2 and Major Stryker.
Reply 155 of 492, by MKT_Gundam
About the LGA 775 chipsets compatible with win 98 (mine is 865G) will work with pci soundcard in dos?
Reply 156 of 492, by ruthan
Yes. you use at least SB !Live, SB Audigy - Windows for which exist Win98 drivers, there are lots of models, Aureal V1/V2 and Yamaha 7x4. My recommendation is Aureal or Yamahas.
For info is in this thread, Yamaha threads.
There is compatibility matrix with X58, i865 would be same or better, not worse, with Yamaha is the same:
https://docs.zoho.com/sheet/published.do?rid= … 04bf92a9209e034
My X58 + sound thread with zillion other info:
X58/i865/V880 - Yamaha7x4/AurealV1/2 pure Dos7.1- compatibility list/research/ultim. drivers configs, WIP- gurus needed
Reply 157 of 492, by MKT_Gundam
ruthan wrote:
Yes. you use at least SB !Live, SB Audigy - Windows for which exist Win98 drivers, there are lots of models, Aureal V1/V2 and Ya […]
I planning make a high end win98se ( later dos and win games) and Xp for Dos box and early XP on same machine.
Reply 158 of 492, by ruthan
Because someone was able to make Win98SE on Z170 chipset working - highend could be misleading:) But i know what you mean, i865 is fine, dos compatibility mainly depends on sound cards and Win98 if you to use Dos mode within depends on used videocard (Nvidia has ugly bug which is blocking to use fullscreen on geforce 4-7 afaik at least with some drivers) and XP 32bit would be running on everything.
Reply 159 of 492, by ruthan
Other bad news for AurealV1 in DOS, beside that its not working with slowdowners propers, it has also problem with Rayer MTRR (blicking cursor after execution, FASTVID is working fine).. graphics boost utility at least with X58 board, but guess is that is will fail on other MBs too, even i not load driver, MTRR is working fine.
