8-bit sound card on FPGA
First post, by newold86
While working (very) slowly on much more complex project inspired by the discussion, decided to make a simple SB-like card with DSP part (and OPL DAC) inside of FPGA, and original OPL2 chip just to test some ideas:
Reply 2 of 45, by shock__
Great effort 😀
Personally love the wavy routing. What package is that FPGA?
Minor suggestion: Make sure there's no solder mask on the ISA connector ... that can lead to issues over time and/or look bad after a few plug/unplug cycles.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 4 of 45, by Error 0x7CF
Awesome! It'd be very cool if there could be an FPGA sound card like this that could be reconfigured via a DOS application to a variety of different cards. Of course, SB clone is also awesome.
Old precedes antique.
Reply 7 of 45, by newold86
Tiido wrote:
MAX10 <3
What does it mean ???
Reply 9 of 45, by newold86
keropi wrote:
<3 looks like a sideways heart so it means Tiido really likes the MAX10 fpga
Looks more like a butt 😀
Reply 11 of 45, by Tiido
Hahaha, <3 is meant to be a heart so Keropi is right here. I like MAX10 FPGAs and I use them on several things.
I dont see any DAC, I suppose you're doing PWM/PDM there for sound output ? Or maybe it is under the YM ?
Reply 12 of 45, by appiah4
Which in itself is not always less desirable than a heart.. but I digress.
Reply 13 of 45, by Scali
newold86 wrote:
(and OPL DAC)
Interesting.
My question is: how did you implement this?
Do you have a single DAC that you use for both the OPL and the DSP sample output? In which case, do you just convert the custom OPL output to standard linear PCM, and mix it with the DSP output?
Or do you use two independent DACs, one for the FM and one for the DSP, and mix them in the analog domain?
Reply 14 of 45, by newold86
Yes, just a simple 8-bit PWM with one resistor/capacitor... Converting OPL2 output to parallel 16-bit format and sending only 8 MSBs to PWM (doesn't add a sound quality, but good enough for my purpose).
Scali wrote:
... do you just convert the custom OPL output to standard linear PCM, and mix it with the DSP output?
Yes, just using arithmetic add operation. Again, the quality is a bit weird, but better than expected. Will try to find my recorder later today to provide some examples.
Reply 16 of 45, by newold86
Someone who is not really offended by a terrible sound (probably, noise is more correct word) can try to recognize the game 😀 - https://clyp.it/ezauzslh
Reply 18 of 45, by newold86
Actually, I don't understand why did I get this kind of the distortion effect - sounds like it was almost done on purpose...
Reply 19 of 45, by newold86
Does anyone know how does YM3014 work ??? The datasheet shows 16 bits for each SH cycle (3 unused, 10 mantissa and 3 exponent), but in reality YM3812 is sending 18 bits. I can’t recognize required data just looking at the logic anslyzer screen, and too lazy to experiment 😀
