First post, by W Gruffydd
I get no sound in Windows or Windows MS-DOS Mode, using Line-In with either headphones or 2.1 speakers.
AWE64 Gold model CT4390- caps look good, no traces appear to be damaged.
Abit AB-LX6 (440LX chipset)- bottom two ISA slots recognize the AWE64, but top ISA slot next to bottom PCI slot won't detect card. Mobo does everything else I want just fine.
Windows 95 OSR 2.1
Fresh fdisk/format/windows install in this order:
Windows 95 OSR 2.1 (Typical/Default settings. Selected having "Sound, MIDI, or Video Capture Card")
USB supplement
Intel chipset drivers (infinst_3302, version 3.3.0.2 - June 19, 1998)
Sound Blaster AWE 64 Gold installation CD (Creative Audio Software, full installation)
Unmuted Line-In Balance in Volume Control
During the CD installation, it requests manual additions to SYSTEM.INI, but after rebooting, everything is present.
Device Manager sees the device just fine:
And reports that everything is working, along with zero conflicts:
I've also tested it in MS-DOS mode via Quake 1.06, after setting it up exactly as described in Phil's video. Everything that needs to be checked is checked is in Sound Mixer Control. Quake picks up the card just fine:
I hope I'm missing something obvious.
