First post, by kirikl
I have horible delay in win xp through USB-midi
Win98 having BSOD when I to to install drivers 🙁
So I need something more convenient
Laptop is Sony PCG-505TR with FM synth on it. Pretty cool laptop, thin and light.
Later laptops doing USB-MIDI just fine since like PIII, but - there is no FM anymore
I would like to have some pcmcia card with midi support. Only card I have is REX 5570, but it is stricted to W95 only, I can't make it work even in W98 🙁
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
Reply 1 of 14, by lolo799
I used that card without issues in Windows 98, how did you install it?
Reply 2 of 14, by kirikl
Through the setup.exe, i turned off built in sound card to avoid conflicts and then still nothing. Exclamation point in device manager saying probably I need to update my drivers
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
Reply 3 of 14, by yawetaG
You need to disable the integrated sound in the BIOS. Otherwise there still will be resource conflicts...
Reply 4 of 14, by kirikl
I did and it is still doing that in device manager. I also reinstall the driver again, just to make sure there is no leftovers... 🙁
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
Reply 5 of 14, by lolo799
Just point the device manager to the .inf file from the rex5570.exe archive.
Just extract the .exe in a folder somewhere yourself.
Can you post a scrrenshot of the device manager with the Ratoc card properties open?
Reply 6 of 14, by kirikl
Just trying again now 🙁
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
Reply 7 of 14, by kirikl
Could you please send install disk to me?
I'm having hard time on different computer with Windows 3.11/DOS too
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
Reply 9 of 14, by kirikl
I was able to run it once! It was being some Melody and i was happy and then It's beeping twice and looks like error. So only thing i run is W95 on Compaq Elite LTE. That's the best I achieved
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
Reply 10 of 14, by lolo799
Do you have the Card and Socket services loaded in your config.sys before the 5570 driver for usage under DOS?
Reply 11 of 14, by kirikl
Yep
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
Reply 13 of 14, by kirikl
No, just two beeps
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
PB G4 1.33 / G3 300
iBook Cl 300
Reply 14 of 14, by lolo799
Could you post the contents of your config.sys and autoexec.bat files?
Do you have any other PCMCIA cards to test the port with?
