First post, by mechcentric
My system is a 386sx40 running dos 5.0 (iirc).
I'm getting adlib music, sfx, and digitized sound in the menu, but there are not door, gunshot, or voice sounds in game (which I assume are digitzed).
I'm using a CT2230 or CT2290 Sound Blaster 16 with the integrated OPL3 chip.
I've attached photos of my autoexec.bat and config.sys
I appreciate any help/suggestions/advice y'all have to offer to remedy this.
I can provide a video of gameplay if needed.
    1.51 MiB
    1.32 MiB
mechcentric
AMD 386sx-40/33/25/20, 4MB SDR, CT2230
Intel 486dx2-66, ATI Mach32/64 VLB 1+1MB, 16MB SDR , CT2290
Pentium MMX 166, ATI Rage II + DVD, Voodoo1, YMF718-s
Pentium III 850, Voodoo3 3500, 2x256MB SDR, Aureal Vortex 2 (MX300), 10/100 LAN
Dell P991
Reply 1 of 8, by doaks80
Did you click upload on the photos or just select them?
k6-3+ 400 / s3 virge DX+voodoo1 / awe32(32mb)
via c3 866 / s3 savage4+voodoo2 sli / audigy1+awe64(8mb)
athlon xp 3200+ / voodoo5 5500 / diamond mx300
pentium4 3400 / geforce fx5950U / audigy2 ZS
core2duo E8500 / radeon HD5850 / x-fi titanium
Reply 2 of 8, by mechcentric
Forgot to add them. They're up now.
mechcentric
Dell P991
Reply 3 of 8, by doaks80
How about other games?
Reply 4 of 8, by mechcentric
epic pinball has no sound at all
mechcentric
Dell P991
Reply 6 of 8, by mechcentric
i have figured that out, but i believe there is a conflict, because i get an invalid blaster=Dx argument
i need to figure out how to solve that conflict
mechcentric
Dell P991
Reply 7 of 8, by mechcentric
I put the card in one slot up and everything works now. Weird.
mechcentric
Dell P991
Reply 8 of 8, by LSS10999
It seems Wolf3D expects Sound Blaster at the usual standard location.
At one time I had a CT2290 that defaulted to IRQ 10, DMA 3, and Wolf3D simply froze upon startup. Actually the IRQ and DMA settings on these cards can be changed to standard IRQ 5 and DMA1 using DIAGNOSE as the card doesn't provide jumpers to configure IRQ/DMA.
Not sure if CT2230 is similar to CT2290, though. Also, given that you moved your card a slot up and it worked, it's possible that you actually inserted the card to a slave ISA slot (which doesn't have DMA). I recall ISA motherboards of that time included both master and slave slots, and you needed to look for a master slot to insert things like sound cards.
