Newly made Gravis Ultrasound compatible cards ... what's the degree of interest?
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Newly made Gravis Ultrasound compatible cards ... what's the degree of interest?
Postby root42 » 2019-3-26 @ 16:38
Sure, sourcing parts is no problem! PCB plus Interwave is fine.
Soldering, retro game reviews and more on YouTube and Bonus videos
Me playing games on my 286 and on my Sega MD2 on Twitch
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, schlae AdLib, PC MIDI Card + SC55MkII, XT CF Lite, OSSC 1.6
User avatar
root42
Postby shock__ » 2019-3-27 @ 09:20
Bad news everyone! Slight delay with the production, as the first audit "failed" due to the producer being unable to exchange one of the gerber files.
On the positive side ... there won't be any annoying visible "pool marker" on the board.
EDIT: Never mind ... seems like they went full speed on the audit this time and sent the board off to production already after re-ordering.
EDIT2: PCBs are being shipped :)
User avatar
shock__
Postby Katara » 2019-3-31 @ 04:24
shock__ wrote:Bad news everyone! Slight delay with the production, as the first audit "failed" due to the producer being unable to exchange one of the gerber files.
Great news, I hope there will be enough cards for everyone, I joined this forum just to follow up with the development of the gravis clone, I never thought you will go this far!
Katara
Postby claesbas » 2019-4-13 @ 20:55
Where can I sign up for one of these please?
claesbas
Postby shock__ » 2019-4-15 @ 08:11
Good news everyone!
https://i.imgur.com/PkcxC8w.jpg
Bad news everyone!
JLC PCB fucked up the instructions, meaning the cards ended up with the pool marker being visible when the card is fully populated :(
Even worse news everyone!
Shipping will be a bit delayed ... probably after easter. I'll PM you once your board has been shipped.
User avatar
shock__
Postby root42 » 2019-4-15 @ 08:54
I think the PCBs look lovely.
User avatar
root42
Postby Whiskey » 2019-4-15 @ 09:12
I don't really understand what you mean about the pool marker being visible, but they do look really nice regardless. I guess this means we need to order some components so we can build and test these cards, is there a spreadsheet or parts list thats up to date?
User avatar
Whiskey
Postby root42 » 2019-4-15 @ 09:19
Whiskey wrote:I don't really understand what you mean about the pool marker being visible, but they do look really nice regardless. I guess this means we need to order some components so we can build and test these cards, is there a spreadsheet or parts list thats up to date?
JLC puts a tiny text (like a serial number) on the PCBs, to track quality complaints and such. I never minded them before, but if you don't want them they need to silkscreen them where e.g. an IC will be placed.
User avatar
root42
Postby shock__ » 2019-4-15 @ 09:29
Yup, that's what I originally set the "JLCJLCJLCJLC" marker under the main IC for ... sadly looks like they missed or ignored it.
On another project I've gone as far as scrubbing it off with a fiberglass pen and re-sealing the PCB with some UV-cureable solder resist with mixed results (south of the large FPGA): https://i.imgur.com/BSRqvHy.jpg
Also thanks for reminding me to upgrade the parts list ... it should be the same as for prototype #2 except for 2 more 10k or 0 ohm resistors and the additional 2x5 header for ESP/SPDIF.
User avatar
shock__
Postby keropi » 2019-4-15 @ 11:05
I don't worry about the JLC marker , in fact I can say I don't care about it being there
looking good shock___ !
User avatar
keropi
Postby hard1k » 2019-4-15 @ 12:54
Absolutely awesome! :)
Please have a look at my wishlist (hosted at Amibay)
User avatar
hard1k
Postby Tiido » 2019-4-15 @ 16:44
You can tell them to put the marker to a specific area. An aquaintance suggested putting the message into the gerbers themselves.
User avatar
Tiido
Postby shock__ » 2019-4-15 @ 18:27
Tiido wrote:You can tell them to put the marker to a specific area. An aquaintance suggested putting the message into the gerbers themselves.
Which is exactly what I did ... after they cancelled my original order, so I could add it again. If they said "better luck next time" I'd have been ok with that. Now I have 2 markers and ended up with a 3 day delay. Meh.
User avatar
shock__
Postby cyclone3d » 2019-4-15 @ 19:38
Wow!
But these are still just beta boards so no big deal. Things happen. Not like it is going to affect the functionality in any way.
User avatar
cyclone3d
Postby 640K!enough » 2019-4-16 @ 02:50
shock__ wrote:On another project I've gone as far as scrubbing it off with a fiberglass pen and re-sealing the PCB with some UV-cureable solder resist with mixed results (south of the large FPGA): https://i.imgur.com/BSRqvHy.jpg
On a few boards, I actually scraped very carefully with a sharp, stiff blade. When the deed was done, you could hardly tell that anything had been there, and there was very little observable effect on the solder mask.
When dealing with smaller boards, you can save a few dollars by creating your own panels. I did that with one adaptor board I used for my early ROM module experimentation. I got 20 of them for the same price as five, and the marker was placed on the break-off tab above the usable boards. Now that I've done that successfully, it may be a way to cut costs on future ROM module production.
640K!enough
Postby MJay99 » 2019-4-16 @ 15:41
Only fyi: I just ordered a couple of PCBs for another card from elecrow in SZ, which I'm gonna populate over the next days to test: They didn't put any pool marker on this batch.
MJay99
Postby matze79 » 2019-4-17 @ 12:22
cyclone3d wrote:Wow!
I`m pretty sure they will work perfectly as the last prototype did :)
https://www.retroianer.de
matze79
Postby shock__ » 2019-4-17 @ 22:07
You are correct ... just assembled one board: https://i.imgur.com/a2okbvq.jpg
Only did major testing so far (output via demo/xtc-play, RAM test, ROM dump + checksum), but looks like no new issues were introduced. Meaning the design is final unless something severe pops up.
EDIT: Updated partslist will follow tomorrow.
User avatar
shock__
Postby Tiido » 2019-4-17 @ 22:35
This looks really lovely, I hope nothing bad is found during testing ~
User avatar
Tiido
Postby 640K!enough » 2019-4-17 @ 22:48
shock__ wrote:Meaning the design is final unless something severe pops up.
We'll have to pay special attention to the 4-MiB ROM bank again. I suspect that the resistor changes will fix the problems with the previous prototype, but I'll only be fully convinced when I hear it.
640K!enough
PreviousNext
Return to Sound
Who is online
Users browsing this forum: No registered users and 4 guests
