ESS SOLO-1 Sound FX
First post, by akosela
Hello,
Has anyone managed to make sound fx work in pure DOS using this PCI card? I am using standard DOS drivers in config.sys and autoexec.bat. It is detected as 220h I7 D1 and MIDI music works but I can't make sound fx work in any game/app I have tried. I am using MS-DOS 7.1 in pure DOS mode.
Reply 1 of 10, by Srandista
On which motherboard?
Reply 2 of 10, by appiah4
It only works on chipsets that support DDMA. What chipset are you using?
Reply 3 of 10, by akosela
GA-H55M-UD2H which has Intel H55 chipset. According to the ESS Solo-1 specs it should work in DDMA and TDMA modes.
Reply 4 of 10, by appiah4
It should. But does that motherboard support DDMA or TDMA? I could not get Solo-1 to work with even i810 unless I used PC/PCI in the past, assuming it would work with the H55 would be a stretch. Cards like YMF724 work with DSDMA and SBLINK on H55 IIRC, but Solo-1 probably won't.
Reply 5 of 10, by akosela
So Yamaha YMF724 is working out of the box on H55? by just using DSDMA.exe or you need SBLink?
I also read about WBDMA on Solo-1 from this thread:
Noob question troubleshooting ESS Solo-1 (ES1938S)
It is supposedly a workaround but should work. Anybody familiar with it?
Reply 7 of 10, by Srandista
akosela: you need to go through this topic (at least through first page):
PCI sound cards and Chipsets from various manufacturers...
Reply 8 of 10, by Stiletto
Moved to Marvin -> Sound.
do the Fandango!" - Queen
Stiletto
Reply 9 of 10, by akosela
I purchased a new sound card based on YMF744 chip and can confirm it does work with H55 chipset using DSDMA. This is probably the best PCI sound card for DOS.
Reply 10 of 10, by Joseph_Joestar
That's a great card. I have a YMF724 and I'm amazed with how clean the output is. Noise is pretty much non-existent, and you get that genuine OPL3 sound of course. Be sure to try PowerYMF if you plan on using it under Windows98 for General Midi. It sounds fantastic with the 4 MB soundbank loaded.
The only advantage the ESS card might have would be Windows Sound System compatibility. Using that or the ESS Audiodrive native driver (whatever's supported in setup) can give you 16-bit sound in some late era DOS games.
My retro builds
