Thanks Alvaro for the test 😀 I believe I am still the only one who tested a GUs on a 8088.
I already corrected many problems on XM files Loading: 16 bit samples, loading bug if there are instruments with multiple sample, Add for some more effects and so on.
.S3M File compression is completed (Note Cut, with Note=255 was causing the last bug)
I am working on the .XM bugs because it is also frustrating for me to have so many .XM not playing at all.
I also progressed on the tests with real hardware, I was able to play modules on a Tandy 1000 EX using the Cvx4: 7.5KHz for 4 Channels and 5KHz for 8 channels. Thanks to the pattern compression, Lots of .MOD files can be loaded completely.
Even at 7MHz, the Tandy 1000 EX is slow, slower than the Atari PC2 or Amstrad 1640.
