Reply 320 of 456, by matze79
Kings Quest 2 also makes graphical glitches without tandy sound.
i tested it.
text seems garbled, this seems an issue with kq2 itself.
Tested with C&T 65550 PCI Card, no issue with 8Bit Paradise VGA
EDIT:
What version exactly do you use ?
i find at least 3 different ones ?
edit: different issue.
Reply 321 of 456, by matze79
https://www.reddit.com/r/dosgaming/comments/d … hrone_graphics/
you have this issue ?
On the Lo-Tech Tandy Compatible Adapter right ?
Reply 322 of 456, by bjwil1991
Yup. How can I tell which version I have?
Reply 323 of 456, by matze79
it seems there are different interpreter versions too..
i have no idea i`m not familiar with sierra stuff.
but my issue has nothing todo with yours.. so its different graphical glitch.. caused by modern card.
do you run with mode -t ?
you run the card on AT ? on 0C0h ? this could be the cause of the issue.
Reply 324 of 456, by bjwil1991
My card is set to 0C0h. I'll change that and see what happens. It's on a Packard Bell Pack-Mate 28 Plus (486) and the GPU is a Cirrus Logic CL-GD5428 w/ 2MB video RAM.
Reply 325 of 456, by matze79
Can you put Tandy Card inside a XT with VGA and try again ?
On 286/386/486+ the DMA Controller #2 uses Adress 0C0h.
Reply 326 of 456, by matze79
Seems there are multiple Versions of KQ2
one using 2.917 and 2.936 Interpreter and there is a Patch for Tandy Sound.
and one with 2.426 and 2.411 Interpreter, no patch.
maybe there is a patch for KQ2 to newer Version ?
Reply 327 of 456, by matze79
Ok grab this Interpreter Update:
http://agi.sierrahelp.com/Files/Interpreters/ … reter_2.917.zip
Unzip it into your KQ2 Directory.
Put AGIT2917.EXE Patch from oldskool.org inside.
Launch AGIT2917.EXE
Reply 328 of 456, by bjwil1991
I only have a 486 present, sadly. I'll try the one you sent to me and see what happens.
Reply 329 of 456, by matze79
I`m pretty sure it will work.
You should also consider to run the card only on 0C0 if needed.
because it will make problems.
For example if i run the Card on 0C0 my ne2000 card seems to disable dma and i get slow performance.
EDIT:
Current Spreadsheet of compatible titles/tested titles
https://docs.google.com/spreadsheets/d/1l907N … E9dLDaxAqt_wt7Y
maybe its time to start a seperate thread soon to get a better overview.
Reply 330 of 456, by bjwil1991
It works. Going to copy the other KQ2 directory and files over to my 486 so that I can have the PC speaker one and fix up my KQ2 batch files to point to the right directories and executables per sound card.
Reply 331 of 456, by psychofox
Can you tell the measurements of the card, (especially the height). I am building an low profile case for my 386, then i know how low can i go 😀
Does this card use - 5 V voltage?
Reply 332 of 456, by matze79
Its 6,2cm heigh, with the ISA Connector.
When plugged in it needs around 5.5cm height. Additional 0.4cm can be freed if non-angled Headers are used for Speaker In / Out
No -5V required.
Reply 333 of 456, by matze79
Everything is packaged... i`m just waiting for the last piece to arrive.. the 3,5mm Audio jacks
Reply 335 of 456, by matze79
I decided to make the DHT Kit too.
i was asked to do so, and the demand is now higher.
So it makes sense and i will not sit on them.
had some soldering fun.. 3,5mm jack box still not arrived.
Seller claimed shipping location is Germany but now i got Chinese tracking id...
i cannibalized some SB128 Cards today.
Reply 337 of 456, by matze79
Here is what the Kit looks like, nothing left anymore 😀
126.24 KiB
162.74 KiB
Reply 338 of 456, by matze79
here are some corrections for Self Builders, in case you cant find the locations for the Parts.
234.18 KiB
C12 is under the IC Socket for SN76489.
Some people did not respond to my messages so i still have Cards left, if someone is interested.
