Reply 320 of 929, by root42
FreddyV wrote on 2020-01-24, 10:34:
DOSBox is bugged for 16 Bit replay with DMA 1 🙁
Luckily the developers have their own sub forum here. So I guess you should report that to them. 😀
YouTube and Bonus
Reply 321 of 929, by FreddyV
To see if it is working, you can check this video:
https://www.youtube.com/watch?v=RGP3_W1SKhw
Sorry for the sound, it was too loud and it is recorded with a Phone.
I definitely need to record directly the sound from the output.
I confirm it is much better in real 😀
Edit: I just tested Mod Master on a friend's 5150, it is doing the mixing at 13600Hz, on 4 Channels modules on a Sound Blaster Pro.
Reply 323 of 929, by root42
FreddyV wrote on 2020-01-26, 15:33:
My Friend released his Video, 5150 Vs Amiga 500
https://www.youtube.com/watch?v=wVmPVR1Xj9Y
Oh, that CGA snow! 😀 Still quite impressive for a slow 5150! I guess an AT would fare much better against the Amiga. The sound quality on the IBM was better, but the UI is of course more impressive and smooth on the Amiga.
YouTube and Bonus
Reply 324 of 929, by Rodrik
Hello
It seems I lost my account here, so here I am again 😀
I hope you enjoyed my video. Yes the sound is different on the IBM compared to the Amiga, I don't remember how to turn off the default hardware filter of the Amiga. Also the IBM is a bit louder but has less impact on bass. Maybe not easy to ear since I do video with only an iPhone.
For the snow on the IBM with CGA, it's a known bug of this old card when writing directly into memory.
You are welcome to comment on the video even if it's in French.
Rodrik
Reply 325 of 929, by Rodrik
Hello again, I made English subtitles to this video, so enjoy, comment and like it 😀
Reply 326 of 929, by FreddyV
Here is the release 15.
I believe this one will be interesting for Root42 as it improved the sound quality even for the 8 Bit Output (BlasterBoard)
30/01/2020 Beta 15
- Corrected the Note Delay command (It was no more working)
- Corrected a problem in DOPE.MOD (One Octave was missing)
- Improved the Options menu
- All the options can be changed with the keyboard (first letter of the option name)
- Corrected the Command line help.
- Remove some french words here and there.
- 8 Bit Volume table precision improved. The volume level needs to be reduced (If you already adjusted it)
- 16 Bit Mixing Added, for 8 Bit output, and 16 Bit output on Sound Blaster 16. (Use mode memory: 16Kb)
- Stereo replay up to 44KHz (22KHz in 16 Bit)
- Number of Octave option now correctly loaded/Saved.
- Config file renamed (MODMXT.CFG)
Some advice to use this new version:
- If you customized the volume for some module, you will need to reduce it.
- Some module may "Crack" even with the default volume.
- It is difficult to feel the difference between 8 and 18 bit mixing, but if you try by reduce the volume, we can hear the difference quite rapidly.
I also suppose I am close to be able to release the Mod Master XT "Officially", as I did clean most of the interface and stability problems. (I Hope)
Reply 327 of 929, by dr.zeissler
What soundcard has the 5150?
Reply 328 of 929, by root42
dr.zeissler wrote on 2020-01-30, 19:20:
According to his earlier post it’s a SoundBlaster Pro.
YouTube and Bonus
Reply 329 of 929, by dr.zeissler
Soundquality is really excellent even compared to the amiga.
Reply 331 of 929, by root42
Here are my tests with the latest beta:
https://youtu.be/ErTkQSvh_ls
I have tested with the SnarkBarker and the BlasterBoard. I used 22 and 44 kHz, switched between 8 and 16 bit mixing (I guess).
I must say the SnarkBarker is way worse due to it's hefty low pass filter. The BlasterBoard sounds great with 22kHz at 16 bit now. I think it's better than at 8 bit, but it's hard to tell actually.
YouTube and Bonus
Reply 332 of 929, by FreddyV
root42 wrote on 2020-01-30, 21:37:
Here are my tests with the latest beta: […]
Yes I hear the difference between the BlasterBoard and the other card. It is like in the Rodrick Video, comparing the 5150 with the Amiga using its filter.
The difference between 8 bit and 16 bit mixing, with 8 bit output is on the last 2 bit only. If we reduce the volume , we can hear a big difference anyway.
I also saw in the last post from LABs that the BlasterBoard output is 12 Bit with an interpolation. I will see with him if he can implement 16 Bit DMA command to 12 Bit. It can be fun to test.
Now I work to add VGZ/VGM Files by starting SBVGM.EXE To have Mod Master playing Tandy and Adlib music through SBVGM 😀
Reply 333 of 929, by LABS
FreddyV wrote on 2020-01-31, 08:23:
OMG 🤦 where did you see it in my last post? There is no such thing, BB has an 8-bit DAC.
A long time ago I was guessing that it can be possible, so I include 8-pin DIP socket for DAC, so anyone could change it to 12-bit easily if it will ever be implemented.
Blasterboard: DIY SB2-compatible sound card on ATmega MCU
Sonic Buster 8: New 8-bit ISA sound card
Reply 334 of 929, by LABS
Thanks for the comparison! Very pleased with the difference too, very inspiring. Can I borrow the video link to my BB thread?
And thanks Freddy for 16-bit mixing that does magic and for the BlasterBoard support. Great stuff.
Reply 335 of 929, by DevanWolf
Have you tested SUBGIANT.S3M and SPACVOY.S3M each time you tested your new versions? (And have I asked you to upload a video with those songs I sent to you?)
Reply 336 of 929, by root42
LABS wrote on 2020-01-31, 16:19:
Sure you can link it!
YouTube and Bonus
Reply 337 of 929, by FreddyV
LABS wrote on 2020-01-31, 16:00:
I did read it in another post probably, I am reading too much 😀
Did you add interpolation ?
Reply 338 of 929, by FreddyV
DevanWolf wrote on 2020-01-31, 16:22:
I did correct various things in the files you sent me, but I did not chech these 2 music.
Is there something special in them still not supported ?
Reply 339 of 929, by Rodrik
I revised the IBM 5150 vs Amiga 500 battle, the winner is .. 😀 Go watch:
https://youtu.be/cCLsvhZiuGo
This video is English sub-titled.
