Doom 2 MIDI OPL3 issue
First post, by daikatana_
Well, it's not exactly an issue. I'd like to ask about a weird problem I'm having, while playing MIDI files using OPL3 sound cards. I usually use Windows 98 to play back some MIDI soundtracks using different wavetable cards. Yesterday, I found out that Doom 2 (haven't tried Doom, but I reckon it's the same) sounds completely different when playing the actual game (real DOS 6.22) vs playing back MIDI files in Windows 98. First I used Sound Blaster 16, I thought there could be a problem with driver, so I tried different card and of course different drivers, namely Aztech Sound Galaxy Pro II which uses OPL3 chip as well, and they sounded identical in Windows 98, so the problem wasn't drivers or SB16 itself. Then I tried playing MIDI files using Roland SC-D70 and it sounds exactly the same as the actual game running with general MIDI driver. Then I tried many DOS MIDI players and the only one of them sounds identical to the game, MUS Player, which is designed to play specifically Doom music.
So my question is, why does Doom sound different using OPL3?
Cheers
Game MIDI soundtracks
Retro games and HW reviews
Reply 1 of 5, by kolderman
Because OPL3 is not midi.
Reply 2 of 5, by foil_fresh
the sound formatting of how the midi track is structured/mastered is likely different to how the in-game tracker plays the adlib standard FM audio - i think there are more effects that midi can do that FM can't, which is probably why it sounds different.
Reply 3 of 5, by Oetker
Yes it depends on how midi commands are mapped to the OPL. The SB16 and Aztech sounding the same in Windows isn't even a given, they probably just use the same driver internally but a different sound card maker might decide to have his own midi->OPL conversion.
Obviously the game does things its own way, and there's even ways to change that: https://github.com/sneakernets/DMXOPL
Additionally a .mid file might not match a game's internal midi format, so even a GM device might sound different between playing a file and actually listening in-game. I think Doom files fine, but for example the midi files that come with System Shock on Steam are way off due to a flawed conversion process.
Reply 4 of 5, by Joseph_Joestar
Oetker wrote on 2020-02-20, 07:47:
I read something similar about Duke3D as well.
Supposedly, the music sounds slightly different when played in-game.
My retro builds
Reply 5 of 5, by daikatana_
I actually used .mus files straight from the Doom .wad file.
Anyway, thanks for clearing that up, guys.
