Reply 140 of 644, by JazeFox
matcarfer wrote on 2020-06-16, 02:21:
P3 866 + Soyo SY-7VBA133 + 512 (I know, too fast)
OPTi 82C931 ExpertColor MED3931
Yes, that's the problem. In my Celeron 566 system with similar VIA chipset board, these OPTi cards without proper oscillator behave the same.
You can solve it if you have some soldering skills:
For MED3931 card:
1- Remove R1 SMD resistor
2- Add a 14.318 Mhz crystal oscillator to X1
Optionally, you can add ~10pF SMD capacitors to C9 and C10
Problem solved 😀
Reply 141 of 644, by matcarfer
JazeFox wrote on 2020-06-16, 13:33:
Yes, that's the problem. In my Celeron 566 system with similar VIA chipset board, these OPTi cards without proper oscillator beh […]
For MED3931 card:
Problem solved 😀
No problem then. I do not need to make it work in this PC, I just wanted to report in case there was a compatibility problem with unisound. Will re-test this card later though with a slower machine. Thank you!
Reply 142 of 644, by zyga64
Please add PnpID [MDK1605] - this is Highscreen Soundboostar 16 - card based on AD1816AJS chip.
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 143 of 644, by schmatzler
Do you plan on adding support for the OPTi 82c929a chipset in the future?
This is actually one of the good OPTi chipsets.
It should also be well documented - the source code for new drivers is available here:
https://github.com/JKnipperts/OPTi82c929_Driver
Reply 144 of 644, by matcarfer
schmatzler wrote on 2020-06-21, 12:50:
Do you plan on adding support for the OPTi 82c929a chipset in the future? […]
I already contacted JazeFox for this (I have a bunch of them) and said that OPTi82C929A arent PnP so he cant/wont support them for the moment.
JazeFox respose: Re: Universal ISA PnP Sound Card Enabler for DOS v0.71c (UNISOUND)
Anyway, nice find, didnt know that driver existed. Thanks!
Reply 145 of 644, by matcarfer
@JazeFox
Ok, I tested a new batch of cards:
-ALS120, ES1868F and proper OPTi 82C931 (with a 14.318 Mhz crystal oscillator), all worked great.
I had problems with 2 cards, both with Crystal CX4235-XQ3 chip.
-1st one (generic) appears to be non-pnp so I cant seem to initialize it with Unisound
-2nd one (Genius) its a PnP card, it gets initialized, but I can't get ANY sound on any game. What could be the problem? Do you need a dumpp?
EDIT: all Crystal CX4235-XQ3 cards are dead...
Reply 146 of 644, by JazeFox
zyga64 wrote on 2020-06-20, 16:01:
Thanks for reporting. I had some ID additions ready for 0.72b (including yours) but I forgot to add them at the end. They'll be added in the next version.
matcarfer wrote on 2020-06-23, 03:21:
@JazeFox Ok, I tested a new batch of cards: -ALS120, ES1868F and proper OPTi 82C931 (with a 14.318 Mhz crystal oscillator), all […]
@JazeFox
Thank you for all the testing work!
Wow, it seems you have a lot of cards for testing!
I sent a PM to you.
Reply 147 of 644, by cyclone3d
I need to go ahead and test out a bunch of my sound cards.
Is there any specific cards that still need to be tested? If so, and I have any of them, I'll test those first.
If not, I'll just test everything and report back as I test them.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 148 of 644, by JazeFox
@cyclone3d
Great! Thank you for your support!
Nothing specific, just test what you can (or want).
Reply 149 of 644, by Oetker
My Compaq Deskpro's built-in ESS isn't detected. I already uploaded a dump before: download/file.php?id=81157 PNPBDV07.TXT
Reply 150 of 644, by JazeFox
Oetker wrote on 2020-06-26, 19:23:
I don't see any ESS card in those dumps. I only see an Aztech 2320 card there.
What ESS chip is mounted in your board?
Reply 151 of 644, by Oetker
JazeFox wrote on 2020-06-26, 20:09:
That text file contains the card info, ES1869.
Esscfg works fine.
What is strange about this system is that disabling devices in the bios still means windows sees them, but can't assign resources. You have to 'hide' them in the security settings to completely hide them from Windows.
Reply 152 of 644, by JazeFox
Oetker wrote on 2020-06-26, 21:13:
Esscfg works fine.
When you say "isn't detected", what's exactly the issue? Unisound does not detect PnP cards or does it say it's not supported / it's and unknown card? The same behaviour happens with the ESS audio enabled or disabled in BIOS?
If no PnP card is detected, it could be because the built-in ESS is only presented by the BIOS as a PnP BIOS node (now I see it as such in that TXT dump). As Unisound does not use BIOS calls (it does direct ISA communication only,), that can be the cause.
Reply 153 of 644, by Oetker
JazeFox wrote on 2020-06-26, 21:44:
When you say "isn't detected", what's exactly the issue? Unisound does not detect PnP cards or does it say it's not supported / […]
Esscfg works fine.
UniSound does not detect any PnP cards. Enabling/disabling in the BIOS doesn't change the behavior. I guess your explanation makes sense.
Reply 154 of 644, by ShovelKnight
@JazeFox, thanks a bunch for this amazingly useful tool! I had all kinds of problems with Crystal's own DOS drivers, but your tool works like a charm with my CX4237.
Reply 155 of 644, by MJay99
ShovelKnight wrote on 2020-06-26, 23:13:
Indeed, used it for the first time today on a PNP SB AWE32 - what a bliss! Detected, initialized and simply worked after that. An awesome tool, thanks!
Reply 156 of 644, by Oetker
Esscfg works fine.
Just to be sure, here's a dump with the card fully configured and playing sfx in Doom.
Reply 157 of 644, by Shreddoc
JazeFox wrote on 2020-03-13, 00:32:
Hi there! […]
Hi there!
I am new user of this forum. I read it over the years but I thought I had nothing to contribute, until now (I hope) .
I made a DOS tool for my own use some months ago, but now I decided to release it, because I think it may be useful for someone else, so here it is:
It is called "Unisound", or Universal ISA PnP Sound Card Enabler for DOS. Current version is: v0.72b (Download link at the end of this post).
Hi JazeFox, many thanks for making this tool. I'm getting back in to ISA sound cards, and it's a real boon to have this unified driver available for DOS.
I am having problems finding working DOS drivers for my AD1816JS + YMF704C-S based ISA card. It is a rare card called "Gallant SC70P PLUS". The Device Id is AXS7180.
I had noticed in your version update v0.71c
- Enable on-board WaveTable sound on AD181x cards with YMF704/QS1000 WT ICs
It seems UNISOUND may (?) already have the foundation in place, to support my card. However, currently UNISOUND says my card is unsupported ("Not compatible yet"), and will not load. Could you possibly help please?
Reply 158 of 644, by JazeFox
MJay99 wrote on 2020-06-27, 00:00:
Great! I'm gald the tool is useful for you 😀
Oetker wrote on 2020-06-27, 07:45:
Yes, it's confirmed, it's the same as before (sorry for the delay). Nothing to do there.
Reply 159 of 644, by JazeFox
Shreddoc wrote on 2020-07-07, 08:01:
This card will be supported in the next version. Stay tuned the next few days.
