Reply 40 of 159, by badmojo
Freaking awesome - this thing looks and sounds terrific!
Reply 41 of 159, by dreamblaster
not decided on colors, first small next batch will probably be green.
Some more tests : see attached files.
Thanks for your support !
Reply 42 of 159, by Joseph_Joestar
That sounds awesome!
EDIT - can you give an estimate of the dimensions? I'm wondering if it can fit on my Avance Logic ALS100. In centimeters please, for us Europeans.
My retro builds
Reply 43 of 159, by dreamblaster
dimension : 80mm x 60mm
Reply 44 of 159, by canthearu
It's going to be expensive, but i NEED one of these!
Take my money, Plz send when ready 😀
Reply 45 of 159, by Joseph_Joestar
dreamblaster wrote on 2020-07-12, 12:18:
Looks good in terms of length. I am a bit worried though since my ALS100 has some rather tall capacitors below the wave table header, so I'll probably get one of your gameport to wave table adapters, just to be safe. That would also allow me to put this on the AWE64 and the YMF724 which is great.
Anyhow, put me down for one when you do the first batch.
My retro builds
Reply 46 of 159, by SodaSuccubus
I'm getting some real SC-55 vibes from those sound test.
Was the original Cancun FX a cooperation with Roland?
Reply 47 of 159, by hard1k
Dream used Roland samples without permission 😀
Roland filed a lawsuit, and finally they settled everything. After that the GS logo appeared on many products with the Dream synths/ROMs.
https://www.eetimes.com/atmel-and-crystal-sem … oland-corp-u-s/
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 48 of 159, by Salient
Count me in for one of those cards too!
Reply 49 of 159, by dreamblaster
Another quick demo : playing rise of the triad in DOSBox, and connected to Yucatan FX using midi interface : 'Goin' Down The Fast Way'
Reply 50 of 159, by kolderman
Is there any point getting one of these if you already have a diamond monster 4mb daughter board?
Reply 51 of 159, by schlomoe99
Most impressive, great work as always!
Reply 53 of 159, by Trelokk
Will it be possible to attach one of these to the upcoming X8/X16 soundcards? If so, that would be the ultimate overkill.
Reply 54 of 159, by keropi
I have made some Rise of the Triad in-game recordings with both the GMS963200B bank and a SC-55 mk2 - same machine same settings and recording system, same everything.
So everyone will be able to judge how close to the roland hardware this is and if it suits their needs.
There ARE differences of course - it's totally different sound engine and fx processors , different chipset in other words. So hear for your self 😀
Tracks are 192kbps mp3 files so the forum player can use them.
Reply 56 of 159, by cde
Sorry if that question has already been asked: I already own the Dreamblaster X2 which is great. What are the advantages of using Reptile Paradise vs the X2?
Reply 57 of 159, by darry
keropi wrote on 2020-07-13, 20:12:
and one last track - one of my favorites Havana Smooth , hope you enjoy the recordings!
Thank you, will listen carefully when I get the chance
Reply 58 of 159, by 640K!enough
keropi wrote on 2020-07-13, 20:10:
There are definitely differences between the two; in particular, the Yucatan seems far more bass-heavy. Is that just the result of using that synth and sound set, or was that specifically one of the goals for the design? It seems a little excessive to me.
