Reply 20 of 29, by Warlord
This is a copy of my Dos driver files. put it in C:
You go YMFIRQ 11
Then setupDS
then LoadTSR
This is the windows VXD drivers use these
http://cdgenp01.csd.toshiba.com/content/suppo … s/t820snd95.exe
    YAMAHA.7z
    1.09 MiB
    50 downloads
Reply 21 of 29, by vorob
Dear Warlord, any chance to get you time for writing a complete step-by-step guide on how to set up sound and music in DOS? Tomorrow I'll have Toshiba Satellite 2805-S401 with Yamaha YMF754B-R and S3 Savage/IX 8Mb, and such a guide will be a time saver!
P.s. at first I thought that https://www.philscomputerlab.com/ is dead, but looks like i have to use VPN to visit if from Russia 😮
Reply 23 of 29, by Prez
Hi !
Okay i did that, everything seems okay under windows ! i could lunch Doom, DEscent, PRince of Persia, etc etc all ok !! with either GM music (very nice) or OPL3, and both with sounds, great !
But what about pure DOS games ? I still have irq problems on DOS mode, it doesn't seem there is a solution for this mode 🙁
Best regards
Philippe Dubois
Old computers and videogames freak
President of french association https://mo5.com
Get better, get old ! 😁
Reply 24 of 29, by Prez
Okay on DOS i did what you told :
For Dos.
1. You have to use the modified 810/815 driver I'll link.
2. The SET Blaster Parameters. are SET BLASTER=A220 I7 D1 T4
3. I already configured this in the driver I am going to link here. But if you use the one off Phils computer page you need to change somethings to get it to work.
4. If you use some other driver than the one for here. Be advised that the one from phils has the wrong environmental variables set up in the batch file and you need to change that.
5. To configure you go "YMFIRQ 11" without quotes at the command prompt.
6. Type SETUPDS Change it to S-IRQ and then you can change it to I7 220 D1 ETC. With the driver I will link it should already be setup for you. Then save.
7. Then to run the driver you type Loadtsr at the command prompt that's all.
But it doesn't work. In SetupDS, with S-IRQ, it doesn't recognise any IRQ i select and can't save.
Best regards
Philippe Dubois
Reply 25 of 29, by Warlord
Post screen shot of microsoft system information. And did you use the driver I linked and put it in C:\Yamaha
You can try inserting a fresh DS.INI and see if it lets you change things. That will undo the settings. in DSSETUP
    ds.ini
    353 Bytes
    14 downloads
Reply 26 of 29, by Prez
Warlord wrote on 2020-10-19, 22:51:
Hi !
First the bios settings. I did what you told about the Parallel port :
169.56 KiB
137.76 KiB
Reply 27 of 29, by Prez
Now when i try to use your files in C:\yamaha and the last ds.ini you gave :
First launch the ymfirq 11 :
95.77 KiB
Then i launch setupds.exe and i have this :
238.59 KiB
Then i change to S-IRQ and modify IRQ to 7 :
230.79 KiB
But i can't save with the typical error message :
195.13 KiB
Reply 28 of 29, by Prez
In Windows, i installed the VXD driver and changed the legacy IRQ to 7.
174.3 KiB
Every thing is working like a charm ! I can play Doom, Descent, Tie Fighter, Prince Of Persia, Dune either with OPL3 music or XG music, its great !
Reply 29 of 29, by Prez
Still no luck under MSDOS whatever i try.
I'm very interested to understand what is wrong with this computer ! 🙁
