Reply 60 of 424, by SScorpio
subnet_zero wrote on 2021-01-25, 14:32:
How about an USB interface and audio out on the McCake like it is on the Dreamblaster X2? Like for Routing the Dosbox MIDI to this device.
Wouldn't it be better to just run Munt or a Soundfont directly on the host machine if you are running Dosbox on a modern machine? You could also just run MT32 Pi on a regular Pi 3/4 rather than a ComputeUnit 4 and get what you are asking for.
Reply 61 of 424, by subnet_zero
SScorpio wrote on 2021-01-25, 14:37:
Yep, you 're right. I obviously didn't thought this through.
Reply 63 of 424, by dreamblaster
New revision of board...
    1.42 MiB
Thanks for your support !
Reply 65 of 424, by dreamblaster
Here's a first test, Silpheed MT32 track : https://youtu.be/W1HHudGXREA
Reply 66 of 424, by dreamblaster
Some more photo's
    1.11 MiB
    1.24 MiB
    1.15 MiB
Reply 68 of 424, by dreamblaster
claesbas wrote on 2020-11-18, 22:54:
So I can just plug this into my MPU 401 ISA cards wavetable and get full mt32 sound via Munt?
Yes that is the idea, perfect companion for Keropi's MPU / Orpheus card
just plug on wavetable header
and also, it needs additional power through floppy cable (due to the high current).
You can also power through wavetable header, but that is only suitable for high current interfaces, like the new CHiLL II
Reply 70 of 424, by dreamblaster
I will make a new revision.. with a tiny display on it as well
Think it would be a nice addition.
the display could be local on the board,
or optionally extended to a 3d printed 3.5inch bay plate.
    35.81 KiB
Reply 71 of 424, by root42
The display would be awesome. That plus the Chill2 board with a 3D printed case could make for some really awesome MT32 replacement!
YouTube and Bonus
Reply 72 of 424, by dreamblaster
root42 wrote on 2021-02-02, 10:27:
Yes i will make a special lid then, to make room for the display 😀
Reply 73 of 424, by schlomoe99
dreamblaster wrote on 2021-01-31, 15:53:
I will make a new revision.. with a tiny display on it as well Think it would be a nice addition. […]
Yes, that would be perfect!
Reply 76 of 424, by dreamblaster
kisscool wrote on 2021-02-17, 18:24:
Daddy (private joke only Serge can understand), this is just awesome ! I just can't wait 😀
Patience, my son...
I'm designing the new revision with display...
Reply 77 of 424, by Cyberdyne
Hope there will be a final pruduct "budget" option without the display, only the interface for connecting the compute module to your waveblaster header.
Reply 79 of 424, by mothergoose729
Love this project! Feature request time!
Will there be ways to cycle ROMs for munt (CM32L, old MT32) as well as load different sound fonts from within DOS like you can with MDF and a midi PC emulator?
