Reply 320 of 644, by 640K!enough
MJay99 wrote on 2021-03-16, 12:03:I'd also have something for him to look into, if or when he returns (a combination of an ESS 1868 with Ultrasound), where unisound seems to reset the PNP config of the ESS on any startup:
This may be related to the problem I described in this post, though the tool I posted also has its own problems with some PnP BIOS implementations.
MJay99 wrote on 2021-03-16, 12:03:But the config of the ESS is lost (every time) - see IRQ / DMA settings:
Is it really "lost", or is it related to the re-location of the RDP? If you use "UNISOUND /Cx /R", where x is the number of the card in question, does UNISOUND still report the correct resources? I haven't tried the newer versions of UNISOUND released since that time, so I never really checked whether his improvements made a difference.
