First post, by mihai
Hi
I have a Sound Blaster Live, model SB0060. The card works great.
The card is supposed to support 5.1 speakers; it has three outputs in the back. However, I cannot select 5.1 speakers in the drivers or surround mixer.
Am I missing something? I would like to use 5.1 speakers with this card.
Thanks for any idea.
Reply 2 of 9, by cyclone3d
Jorpho wrote on 2021-04-15, 22:34:
Three outputs? Shouldn't it have five? maxresdefault.jpg […]
I think you need a TOSLink cable for the orange output.
https://www.amazon.ca/Digital-Audio-Cable-Opt … e/dp/B0002JFN1A
No, you have the top output which is digital out... uses a special breakout if I remember correctly.
Then you have two speakers each for three of the 3.5" plugs. Front should be one plug, rear should be another plug, and center/sub should be another plug.
Pretty sure they are labeled as such.
Also... which operating system and what drivers are you using?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 9, by auron
yeah that's certainly not toslink, it's a mini-jack instead of the standard RCA connector but if i recall correctly it's possible to use this as a digital out via a simple mono adapter plug. i also seem to vaguely recall something about differing signal levels compared to standard though so maybe that might not be a good idea.
@OP, pretty sure you need to set the speaker config in windows, under win9x that would be under multimedia in control panel.
Reply 4 of 9, by yawetaG
cyclone3d wrote on 2021-04-16, 00:08:
I have a set of speakers from Dell that uses such a cable to provide a 5.1 or 7.1 setup on a Dell motherboard with integrated sound. IIRC, it plugs into all the sound card's outputs, and then the signals are routed to a special hub that provides further distribution.
Reply 5 of 9, by mihai
Thanks for the replies. I am using windows 98 and I can choose 5.0 in the OS settings, but not 5.1.
Third output is labeled 'digital / line out 3' this I why I still hope the card could work with 5.1.
Reply 7 of 9, by mihai
Unfortunately, this is it 🙁. The card is the model SB0060, however, it is installed with the device id of CT4670.
I guess I will need to buy an eeprom programmer, hopefully it will work to rewrite the eeprom on circuit.
Reply 8 of 9, by auron
why would the card install with a different device id though?
Reply 9 of 9, by cyclone3d
You actually just need the correct driver installer.
See here for a driver that supports the SB0060:
https://msfn.org/board/topic/115903-compilati … for-windows-9x/
You will need to create an account to download most stuff. However, in that post, it looks like everything is mirrored on mgdx.com
http://www.mdgx.com/sbdrv/
YMF7x4 Guide
