Reply 20 of 21, by badmojo
- l33t
ux-3 wrote on 2023-07-25, 22:15:But I would also like to use a SB 16/32 combatible card like the AWE 64 Gold.
The YMF (Yamaha) chipset includes excellent WSS support, so you can get 16 bit support that way instead of using SB16. Just a suggestion!
Multi card setups are quite possible but I've always found them to be awkward with regards to mixing the output. You can pipe the out from one to the in of the other, or use a mixer of course - it can all work fine but there are a lot more variables than just having one nice card setup.
