This is the Sound Blaster Pro 2 update (CT1600)
You can download the files in one go here : https://docs.google.com/open?id=0BzsnL20-4a37UFUxMGgzcFlONkk
Or you can go directly to the grand OPL3 Comparison run site:
https://sites.google.com/site/soundcardcomparison/
I felt many things should be said about this card and i fear my short description might be a bit lackluster. If you have some suggestion and relevant infos please share.
I really think i should be trying to turn this project into a kind of Open to all Wiki...
And sry for the long time since laste update, too many geeky projects at the same time
The sound blaster Pro 2 is a well loved sound card, and for good reasons. It is a landmark card often used to compare other cards. ... ( add blah blah... )
I found the output quality to be quite good. Noise level is low, no audible distortion and it packs alot of power in the bass section. When connected to my main sound system this card could generate some quality wall rumbling, I remember thinking how this was a badass card. However when compared to some of my favourite sounding sound cards, I actually find it a bit too boomy. The higher frequencies are cut low and it lacks a bit in brightness for my taste. It is in no way a deal breaker as this card is renowned for its compatibility good quality. You can always EQ it to taste. The mixer settings has a Low pass filter that is on by default. You can deactivate it with the SBP-SET utils included in the drivers. It is supposed to only be applied to Digital audio and not FM, however i did not try it myself and the recordings were done with the default settings.
