Have you opened your SC-55 to check the battery inside?
Discussion about old sound cards, MIDI devices and sound related accessories.
Re: Have you opened your SC-55 to check the battery inside?
Postby SpeedySPCFan » 2018-3-19 @ 04:28
bjwil1991 wrote:The battery was primarily used for musicians, right? Without the battery, that should be OK for PCs (games), if my memory serves me right.
I had my SC-88 Pro without a battery for a few days since I didn't have any replacements on hand. As a musician, it's really nice to have it in since it saves things like the MIDI OUT/MIDI THRU toggle, instrument patches, etc. But for games it saves absolutely nothing of importance and you can keep it removed.
Musician & music gear/game reviewer. Worked on Planet X3, Necrolepsy, and some FPS mods.
My GM compliant MIDI modules: SC-55 (2.00 ROM), Korg NX5R, Triton Extreme, Trinity Plus, Fantom XR, Yamaha MU1000EX. PM me if you want any music recorded in 24-bit quality!
User avatar
SpeedySPCFan
Postby Trelokk » 2018-4-03 @ 13:29
Thanks for this useful hint! I removed the battery yesterday and hopefully saved my unit from a premature end this way. Also good to know that the battery is not needed if you are just using it for games. Won't insert it again, then!
Trelokk
Postby cricket » 2018-4-10 @ 18:55
Thanks for the useful information.
I'll check my SC55 as well.
The original photo is not shown anymore, what kind of battery is in there?
User avatar
cricket
Postby keropi » 2018-4-10 @ 19:11
CR2032 IIRC
User avatar
keropi
Postby aquishix » 2018-4-22 @ 14:04
SpeedySPCFan wrote:I had my SC-88 Pro without a battery for a few days since I didn't have any replacements on hand. As a musician, it's really nice to have it in since it saves things like the MIDI OUT/MIDI THRU toggle, instrument patches, etc. But for games it saves absolutely nothing of importance and you can keep it removed.
Good to know that about that toggle on the SC-88. I'm only using this Roland equipment for DOS gaming, but I have an SC-88, SC-55, and MT-32 daisy chained in sequence so that I can use both MIDI inputs on the SC-88 and have the signals cascade to the other modules without having to implement messy switches or fuss with changing cables all the time.
User avatar
aquishix
Postby twilliamc » 2018-7-11 @ 19:44
I am glad this topic is high up. Should be stickied. I saved my SC-155 from death thanks to this thread.
Vendex Turbo-888-XT: 8088, 640K, 360k 5.25FDDx2
Vendex Headstart III: 80286 @ 8/12MHz, 1MB RAM, 2GB CF, 1MB VGA, DOS/HOT/Win 3.0
Unnamed: 486DX4 @ 120MHz, 16MB, 2GB, 2MB VGA, SBPro 2.0, DOS/W3.11, W95
User avatar
twilliamc
Postby Rasna » 2018-8-23 @ 12:47
The batteries in my SC-55, SC-55MK2 and SC-88 Pro had definitely been leaking, no damage to the board and no leaking residue on the blade in the battery holder............
My MIDI modules: Roland MT-32 (old), CM-32L, SC-55, SC-55MK2, SC-88 Pro
Rasna
Postby Rasna » 2018-8-23 @ 12:55
keropi wrote:yep both mt-32 and cm-32L that I have opened do use a 7805 regulator since they are 5v devices :)
I've already replaced them with cooler TSR 1-2450 :happy:
Rasna
Postby CrossBow777 » 2018-8-23 @ 16:38
Does that cause any added noise on the line level outputs that you've heard? I also use these same DC-DC converters in most of my classic gaming consoles. However, when I installed them into the Sega Genesis, I had odd beeps and static that could be heard that was never present before. I also had odd issues with Sonic 3 locking up randomly with them in place. I ended up replacing them back out and putting in higher 2amp versions of the standard 7805 VRs. But that is the only console I've done that with and had issues.
So yeah I'm curious as I have some still on hand and wouldn't mind trying them in my MT-32 or MT-200.
User avatar
CrossBow777
Postby Rasna » 2018-8-24 @ 13:20
I didn't notice any extra noise
Rasna
Postby SpeedySPCFan » 2018-10-02 @ 16:37
keropi wrote:CR2032 IIRC
I got my SC-55 a few days ago, this is correct - it's a CR2032 battery. Mine was a Toshiba brand specifically - not like it matters, my 88Pro and 55 are now running Energizer batteries so they Keep Going and Going™ :lol:
User avatar
SpeedySPCFan
Postby Salient » 2018-10-28 @ 16:08
Replaced mine finally as well in both my SC-55's.
They were indeed in poor condition by now, but haven't damaged anything (unlike the Varta stuff in a lot of Amiga's):
User avatar
Salient
Postby Baoran » 2018-11-02 @ 02:29
I found my first SC-55 for about 40 euros locally about a week ago and I have not checked the battery.
Baoran
Postby MusicallyInspired » 2018-12-06 @ 01:37
Does anyone know if I would have to worry about this with a CM-500 or MT-200? No, eh? There's no memory features on the CM-500 at all IIRC, and the MT-200 saves everything to floppy disks...again, IIRC.
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, Hocus Pocus, Descent, and more.
Latest release: Heretic Music Pack (12/12/18)
User avatar
MusicallyInspired
Postby CrossBow777 » 2018-12-06 @ 08:32
MT-200 has a larger tabbed coin battery in it and it is used near as I can tell to save the RTC information in the sequencer. But I would imagine it could go bad and leak like anything else. I took them out of both of the MT-200s I have and installed standard 2032 coin cell holders and put new maxell 2032 batteries in each.
User avatar
CrossBow777
Postby MusicallyInspired » 2018-12-06 @ 13:46
Thanks. I'll have to do that.
User avatar
MusicallyInspired
Postby Storm82 » 2019-3-26 @ 08:21
My recently acquired SC-55 also had a leaking battery. It wasn't much but I still removed it
Storm82
Postby stalk3r » 2019-4-17 @ 15:27
Should one replace it with a rechargeable one, or with a regular Li-ion coin battery (non-rechargeable)?
User avatar
stalk3r
Postby keropi » 2019-4-17 @ 15:37
stalk3r wrote:Should one replace it with a rechargeable one, or with a regular Li-ion coin battery (non-rechargeable)?
Use a normal CR-2032 , non-rechargeable
you can also chose not to install a battery at all - it will not hurt playback you just won't be able to save settings. I did not install batteries again in mine since all I am using them are for gaming.
User avatar
keropi
Postby stalk3r » 2019-4-17 @ 19:28
Good to know, thanks. I already removed the old one, because it started leaking.
User avatar
stalk3r
Previous
Return to Sound
Who is online
Users browsing this forum: Tiido and 1 guest
