First post, by schlang
Hi, it is possible to control the volume levels of the GUS using commmand line parameters?
The mixer.exe utility is quite ugly and annoying 😀
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 2 of 14, by elianda
This depends on the GUS that you have, the original GUS had no mixer at hardware level.
Youtube Channel
Reply 3 of 14, by schlang
I'm using two GUS PNPs and one GUS MAX
Reply 4 of 14, by megatron-uk
You want ULTRAMIX.EXE, it uses an configuration file called (funnily enough) ULTRAMIX.INI. You can set all the parameters in that file (or simply pass them as command line arguments) and call ultramix.exe in your autoexec.bat just after ULTRINIT.EXE sets up the hardware.
Reply 5 of 14, by schlang
hm doesn't work with my GUS PNPs
Reply 6 of 14, by elianda
The GUS PnP software package doesn't come with a DOS mixer (as the card was already targeted for Windows, like the AWE32).
Either you download the Mixer from the Reveal Wave Extreme32 which is a compatible Interwave card or you use MegaEm.
Thats what the FAQ says: http://www.cwu.edu/~melikd/guspfaq.html
I use an external mixer myself, so this wasn't an issue for me.
Youtube Channel
Reply 8 of 14, by schlang
Couldn't locate the DOS Reveal WaveExtreme drivers, only Win95 🙁
Reply 9 of 14, by boxpressed
Apologies for the necrobump, but the original question is mine exactly. Is there no way to adjust the volume on the GUS Classic from DOS? I want to include it in my wavetable sample thread, but the output is LOUD, and clipping begins almost immediately. I don't have a hardware mixer. ULTRAMIX doesn't seem to have any effect, as elianda suggested above, no matter what settings I include in ULTRAMIX.INI. I also have a GUS ACE. Would ULTRAMIX work with it?
Reply 10 of 14, by peklop
I can`t help but hardware was different between GUS cards:
GUS Classic before 3.7x revision and GUS ACE
no mixex chip
GUS Classic 3.7, 3.73, 3.74 and most of or all GUS clones with GF1 chip:
ICS2101 mixer chip
(v 3.7 with swaped channels error?)
GUS MAX:
CS4231 codec, no ICS2101
GUS Extreme and Synergy ViperMax
ES1688, no CS4231 nor ICS2101
Reply 11 of 14, by boxpressed
peklop wrote:
I can`t help but hardware was different between GUS cards: […]
no mixex chip
ICS2101 mixer chip
GUS MAX:
Thank you, this helps a lot. I installed my GUS ACE, and when you try to run ULTRAMIX, you get a message saying that the ACE has no mixer capability. My GUS classic reports the changes as it if were working, but the volume is always the same.
Thankfully, the volume from the ACE is at normal levels, so I'm able to make a good recording.
Reply 13 of 14, by boxpressed
Rev 3.4. I brought the memory to a full 1MB. 😀
866.06 KiB
Reply 14 of 14, by peklop
Beauty card. But still without mixerchip. It was added to the 3.7x revisions.
If you check photo it is small ICS2101 chip in middle of the card:
https://retrosoundcards.wordpress.com/tag/gra … assic-ver-3-73/
And both Sound M16B and M16C clones used ICS2101. M16B same small package and M16C bigger package.
Maybe is problem in ULTRAMIX. I if program cannot detect difference between 3.4 and 3.7 revision. If expecting mixerchip and use not connected ports, volume isnt changed.
