Reply 20 of 24, by Stiletto
- l33t++
Moved.
do the Fandango!" - Queen
Stiletto
Moved.
Stiletto
I have now finally at home bulk Aopen Yamaha 744 PCI card? Which driver for Dos i should try and how to set it?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
It depends on chipset. For different southbridges there are different patches.
Why in topic about Creative?
I suppose that it also have SB emulation, otherwise it would be half-dead for Dos.
Few notes to SB 16 emulation driver and pure DOs:
I tried same driver with driver with !Live - CT4830 Dos compabitle.. I found 2 things which could help:
CTSYN variable value has to end with "\" character otherwise im getting message that SBport is not set, i checked that this message is used when file is not found, exist.. Its stupid parsing algoritm probably do this ctsyn path value+ctsyn.ini - after it wonders that path doesnt exist..
Other discover is freeze at driver loading, when PATH variable is longer than 126 character what is enabled in MS DOS 7+ but driver is crashing with that, which very strange errors.. Like reboot, loaded freeze.. runtime error, stack overflow and other "beautiful" errors..
I wonder if someone did found documentation to ctsyn.ini what exactly means parameter PCIPort and tis values?
ctsyn.ini in my C:\Windows are using this value b800 , Dos one is 0.
