Simmconn AWE64 Adapter
Reply 400 of 549, by dreamblaster
yes I am going forward with the plan to have factory assembled simmconns
and next to that, I will offer solder kits (but it will require good SMD skills) to solder the plcc
Thanks for your support !
Reply 401 of 549, by timitt
I had time to replace both cmma and cmmb connectors with the first universal unit I got, but it did not fix the unit (even though it now goes all the way down when put to sound card). Physically that unit seems to be 100% fine (I checked all pin contacts everywhere with multimeter too). However when two legs got sucked to desoldering gun when I was removing cmmb connector. Connector legs are REALLY vulnerable so it might be possible that some units have some legs broken and therefore does not have connection to sound card.
So no idea why that unit was working way it was, but since the latest universal unit worked fine I would assume that first one just had to have some chip somewhat broken.
Anyways, I would assume that factory assembled universal simmconns would work fine.
Reply 402 of 549, by goletsa
I'm intrested to buy a couple of kits.
Reply 404 of 549, by maw
one gold for me if still ongoing
BOX#1: new rebuild no case currently | ASUS P5A | Pentium1 200 | 64MB PC100 | Voodoo3 AGP | AWE64 GOLD + SIMMConn| 16GB Kingspec DOM | DVD Drive | Dos 6.22 + Win98
Reply 405 of 549, by dreamblaster
yeah still going, i asked a quote from the assembly factory, these boards will be with sockets
it will be great.
so you could order 1 simmconn and 2 preprogrammed GALs (for example gold and value) to swap out
depending on how you use it.
Reply 407 of 549, by tpowell.ca
33oldnew wrote:
One gold for me, if possible, preferred soldered.
ditto. 😀
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 408 of 549, by KCompRoom2000
dreamblaster wrote:
yeah still going, i asked a quote from the assembly factory, these boards will be with sockets it will be great. so you could or […]
it will be great.
Are you now offering replacement Simmconns for those who got defective ones from the universal batch last October? If so, I'm interested in a Value one.
Reply 409 of 549, by dreamblaster
Yeah, I was already offering replacement if it did not work, the offer is still valid. just pm me with your address and description of the problems.
Reply 410 of 549, by Makatea
Hello all. First post for great stuff. So muss das! 🤣
Nice offer! 😎 I'll take 3 soldered. Two with gold and universal and one with Universal and value. The price is the same - 40+5$? Please PM. 😀
Reply 411 of 549, by maw
dreamblaster wrote:
yeah still going
wonderful 😀
If it helps for the batch I would take also 2 + gals.
Reply 412 of 549, by Lazaros
What is your current estimation as to when these will be available? I'm still down for 4 value and 1 gold as I stated in our pm and I have received the s2 and x2, thanks. Do the GALs work in both the gold and value and what is the cost for an extra set ie. order 5 gold and 5 spare value GALs.
Reply 413 of 549, by dreamblaster
okay here's news :
a batch of 120pcs is ordered and will be ready in april.
I hope this can cover the needs 😀
This is a limited run, and I am aiming for perfection. I will now start accepting pre-orders.
The boards will be automatically soldered and 100% inspected/verified in a Belgian factory.
The cost will be 35 euro for the simmconn boards with empty PLCC socket (so without PAL chip), and 8 euro per preprogrammed PAL chip.
So for one working combo you need at least 35 + 8 = 43 euro.
Shipping (without tracking) will be 2 euro in Belgium, 7 euro in EU, and 9 euro outside EU (worldwide)
(if tracking is needed, add 10 euro)
Available PAL programs are :
- PAL Value
- PAL Gold
- PAL Universal (experimental)
The mainboard is the same, so you can just swap out the socketed PLCC chip (carefully).
So if you like to reserve please pm me with what you like, and your shipping details.
I will get back to you, later, for the payment arrangement (through paypal).
If you already had posted a request for reservation in this thread, please pm me your shipping address,
and refer to your post, to get your priority in the list.
Reply 414 of 549, by maw
Great news 😀
done.
ps. what is the color of the PCB? 😀
Reply 415 of 549, by dreamblaster
black
Reply 416 of 549, by Lazaros
Sorry don't have access to PM, Please reserve 5 adapters and 5 gold and 5 value pal chips. The address is the same as the x2 and s2 you sent.
Reply 418 of 549, by dreamblaster
heldma1m wrote:
I've also no access to PM.
Oh, I didn't realize the pm limitations.
Well, you can contact me through https://serdashop.securearea.eu/Contact
(I will need the shipping address.)
