Reply 40 of 85, by stamasd
More tests done with the "problem games" listed above. Tests were done on the PlatiniX 2E/333, 2.66GHz, YMF724 card with SB-link configured for 220, IRQ5, DMA1; MS-DOS 6.22 with himem.sys; no expanded memory/EMM386 used except as noted below. Results:
1. Games that work without any issues: Descent 1 (setup autodetect crashes, setup sound manually works, needs dos32a.exe to run instead of dos2gw.exe), Epic Pinball, Jill of the Jungle, Mega Man X, Prince of Persia, Sam&Max, Laura and the Dagger of Amon Ra
2. Work after some config work: Wing Commander 2 (without EMM386 only limited sound support: music+SFX work, speech no; with EMM386.exe all work including speech; also game runs too fast with default BIOS setup, but works at correct speed with CPU L1+L@ caches disabled)
3. Major issues:
a-Descent 2: setup can't autodetect sound, but can be set manually; doesn't allow testing of the sound settings though, unlike Descent1. In-game music works, but sound effects are absent. Tested with all available settings (SB, SBPro, SB16) same result.
b-Larry 1 (both the 1987 version and the 1991 rerelease): sound only through PC speaker. Can't figure out how to configure for anything else.
c-Dune: manually setup for SB and manually set IRQ to 5. GAme hangs at the "Cryo..." loading screen. Same happens with L1+L2 disabled. Needs hard reboot.
Police Quest 3 and Space Quest 1: both have the same issue (Sierra games). Manually set sound to SB in install program. Both games hang at loading with a blank screen and a mouse pointer in the middle. Need hard reboot. Same happens with L1+L2 disabled.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
