First post, by boxpressed
- Oldbie
I'd like to get some GM samples from my TB Santa Cruz but cannot get 98SE to load a device driver for the MPU-401.
I am using the 4081 drivers, which are VxD drivers, I believe. Later drivers are WDM.
Everything works perfectly with the card except that there's no way to play GM music from DOS games. There's no discrete driver for an MPU-401 in Device Manager, and the Device Manager's settings for the DOS Legacy mode include settings for SB port, IRQ, DMA, and Adlib port, but no MPU-401.
When I tried to add the hardware manually in Control Panel, I did see a setting for "Santa Cruz Virtual MPU-401," but after I installed it and rebooted, Windows wouldn't load because of a VxD error linked to one of the Santa Cruz drivers.
I'm trying to figure out if I'm using the wrong drivers or if I have a damaged card. I have replicated this problem on a BX and 686B system.
Does anyone have a Santa Cruz up and running on their 98SE system, and do you have a driver for the MPU-401 displayed in Device Manager? Thanks for any help!
